Feature u Think we need to improve?
Audio
51.16%
22
Rear Video
13.95%
6
GPS
34.88%
15
43 vote(s)
Pine64 Head Unit
#57
(07-17-2016, 06:32 PM)CanadianIceTech Wrote: For those that have done this, how are you mounting the LCD touchscreen in the car? The only way I see is to use double sided tape to tape it to something flat (lexan, etc) then mount the lexan into the factory mounting spot. I don't see any place to securely screw into, which I would prefer using screws to mount it as tape would be a semi-permanent solution that may wreck the screen should you have to remove it from the mount.
As a starter you might want to have a look at http://i-carus.com/shop/ , scroll down to the parts where you find a "2DIN housing "iCarus" with integrated switch on/off toggle, rotary button and active USB hub". Or go to http://www.carav-parts.com/ and search for your car brand and model.
There is certainly more out there and collecting these parts here would certainly be useful.
Pine64 Head Unit - by Zoidiano0 - 02-15-2016, 02:26 PM
RE: Pine64 Head Unit - by inzinjer - 02-15-2016, 03:54 PM
RE: Pine64 Head Unit - by Zoidiano0 - 02-15-2016, 04:26 PM
RE: Pine64 Head Unit - by pine.tree - 02-16-2016, 11:50 AM
RE: Pine64 Head Unit - by Zoidiano0 - 02-16-2016, 04:50 PM
RE: Pine64 Head Unit - by pine.tree - 02-16-2016, 06:54 PM
RE: Pine64 Head Unit - by CanadianIceTech - 02-17-2016, 08:23 PM
RE: Pine64 Head Unit - by dulasu - 02-17-2016, 10:26 PM
RE: Pine64 Head Unit - by Zoidiano0 - 02-18-2016, 05:51 AM
RE: Pine64 Head Unit - by dulasu - 02-18-2016, 12:32 PM
RE: Pine64 Head Unit - by TonyH - 02-18-2016, 08:25 PM
RE: Pine64 Head Unit - by Zoidiano0 - 02-18-2016, 10:12 PM
RE: Pine64 Head Unit - by dulasu - 02-18-2016, 11:34 PM
RE: Pine64 Head Unit - by Zoidiano0 - 02-20-2016, 05:18 PM
RE: Pine64 Head Unit - by npull - 03-03-2016, 09:43 AM
RE: Pine64 Head Unit - by Zoidiano0 - 03-03-2016, 08:35 PM
RE: Pine64 Head Unit - by npull - 03-04-2016, 02:46 AM
RE: Pine64 Head Unit - by Zoidiano0 - 03-04-2016, 04:40 AM
RE: Pine64 Head Unit - by npull - 03-04-2016, 07:02 AM
RE: Pine64 Head Unit - by Zoidiano0 - 03-04-2016, 07:59 AM
RE: Pine64 Head Unit - by pine.tree - 03-10-2016, 10:23 AM
RE: Pine64 Head Unit - by Zoidiano0 - 03-10-2016, 04:46 PM
RE: Pine64 Head Unit - by npull - 04-01-2016, 03:54 AM
RE: Pine64 Head Unit - by inzinjer - 03-18-2016, 07:59 AM
RE: Pine64 Head Unit - by npull - 03-18-2016, 10:52 AM
RE: Pine64 Head Unit - by Zoidiano0 - 03-20-2016, 12:52 PM
RE: Pine64 Head Unit - by Zoidiano0 - 03-28-2016, 02:28 PM
RE: Pine64 Head Unit - by burbs - 03-29-2016, 07:14 AM
RE: Pine64 Head Unit - by lejaybo - 03-30-2016, 12:44 PM
RE: Pine64 Head Unit - by Zoidiano0 - 04-01-2016, 05:02 PM
RE: Pine64 Head Unit - by pine.adam - 04-04-2016, 03:27 PM
RE: Pine64 Head Unit - by BeauS - 04-05-2016, 10:44 PM
RE: Pine64 Head Unit - by Zoidiano0 - 04-06-2016, 06:23 AM
RE: Pine64 Head Unit - by BeauS - 04-08-2016, 10:14 PM
RE: Pine64 Head Unit - by Zoidiano0 - 04-09-2016, 05:38 AM
RE: Pine64 Head Unit - by pine.adam - 04-15-2016, 08:22 AM
RE: Pine64 Head Unit - by queonda - 04-26-2016, 05:43 PM
RE: Pine64 Head Unit - by pineman64 - 04-26-2016, 07:07 PM
RE: Pine64 Head Unit - by queonda - 04-27-2016, 10:04 AM
Pine64 Head Unit - by Zoidiano0 - 05-04-2016, 06:51 PM
RE: Pine64 Head Unit - by Zoidiano0 - 05-09-2016, 03:48 PM
RE: Pine64 Head Unit - by files_copying - 05-26-2016, 06:50 AM
RE: Pine64 Head Unit - by ipsw - 06-06-2016, 06:05 PM
RE: Pine64 Head Unit - by Rob - 05-27-2016, 11:44 PM
RE: Pine64 Head Unit - by Zoidiano0 - 06-02-2016, 05:15 PM
RE: Pine64 Head Unit - by Zoidiano0 - 06-13-2016, 06:52 PM
RE: Pine64 Head Unit - by mesaxi - 06-29-2016, 01:28 AM
RE: Pine64 Head Unit - by files_copying - 07-02-2016, 08:57 AM
RE: Pine64 Head Unit - by Zoidiano0 - 07-04-2016, 07:19 PM
RE: Pine64 Head Unit - by Banichi - 07-08-2016, 06:47 PM
RE: Pine64 Head Unit - by CanadianIceTech - 07-17-2016, 06:32 PM
RE: Pine64 Head Unit - by klausr - 07-26-2016, 05:33 AM
RE: Pine64 Head Unit - by Banichi - 07-18-2016, 09:00 AM
RE: Pine64 Head Unit - by Zoidiano0 - 07-18-2016, 10:56 AM
RE: Pine64 Head Unit - by CanadianIceTech - 07-19-2016, 10:16 AM
RE: Pine64 Head Unit - by jodybrown99 - 07-19-2016, 03:01 PM
RE: Pine64 Head Unit - by Zoidiano0 - 07-25-2016, 05:29 PM
RE: Pine64 Head Unit - by ipsw - 08-05-2016, 09:21 AM
RE: Pine64 Head Unit - by Zoidiano0 - 08-06-2016, 08:25 AM
RE: Pine64 Head Unit - by Traveler - 08-06-2016, 09:07 AM
RE: Pine64 Head Unit - by Zoidiano0 - 08-10-2016, 08:00 PM
RE: Pine64 Head Unit - by ipsw - 08-11-2016, 01:29 PM
RE: Pine64 Head Unit - by Zoidiano0 - 08-11-2016, 05:34 PM
RE: Pine64 Head Unit - by ipsw - 08-11-2016, 09:08 PM
RE: Pine64 Head Unit - by Traveler - 08-11-2016, 10:30 PM
RE: Pine64 Head Unit - by ipsw - 08-22-2016, 10:55 AM
RE: Pine64 Head Unit - by Traveler - 08-22-2016, 12:46 PM
RE: Pine64 Head Unit - by Banichi - 08-22-2016, 08:18 PM
RE: Pine64 Head Unit - by ipsw - 08-23-2016, 01:38 PM
Pine64 Head Unit - by SkimMilk - 08-23-2016, 03:31 AM
RE: Pine64 Head Unit - by cesar - 09-06-2016, 04:26 AM
RE: Pine64 Head Unit - by Zoidiano0 - 09-06-2016, 05:57 AM
RE: Pine64 Head Unit - by garry_t - 09-14-2016, 03:09 PM
RE: Pine64 Head Unit - by Zoidiano0 - 09-14-2016, 03:46 PM
RE: Pine64 Head Unit - by mbt28 - 10-05-2016, 09:30 AM
RE: Pine64 Head Unit - by Traveler - 10-05-2016, 10:54 AM
RE: Pine64 Head Unit - by mbt28 - 10-06-2016, 02:50 AM
RE: Pine64 Head Unit - by Zoidiano0 - 10-09-2016, 12:27 PM
RE: Pine64 Head Unit - by Traveler - 10-09-2016, 12:56 PM
RE: Pine64 Head Unit - by mbt28 - 10-09-2016, 02:37 PM
Pine64 Head Unit - by reaper7 - 10-09-2016, 01:08 PM
RE: Pine64 Head Unit - by npull - 01-10-2017, 02:18 PM
RE: Pine64 Head Unit - by tllim - 01-10-2017, 08:50 PM
RE: Pine64 Head Unit - by npull - 01-11-2017, 03:03 AM
RE: Pine64 Head Unit - by tllim - 01-16-2017, 04:35 PM
RE: Pine64 Head Unit - by mbt28 - 01-27-2017, 05:49 AM
RE: Pine64 Head Unit - by Math43 - 02-20-2017, 06:48 AM
RE: Pine64 Head Unit - by clamum - 02-27-2017, 02:34 PM
RE: Pine64 Head Unit - by Traveler - 02-27-2017, 02:45 PM
RE: Pine64 Head Unit - by dkryder - 02-27-2017, 03:22 PM
RE: Pine64 Head Unit - by dikov - 03-03-2017, 01:37 PM
RE: Pine64 Head Unit - by dikov - 03-07-2017, 08:07 PM
RE: Pine64 Head Unit - by pfeerick - 03-07-2017, 09:09 PM
RE: Pine64 Head Unit - by dikov - 03-08-2017, 10:20 AM
RE: Pine64 Head Unit - by ronaldolcc - 03-28-2017, 07:28 AM
RE: Pine64 Head Unit - by dikov - 03-28-2017, 09:30 AM
RE: Pine64 Head Unit - by mbt28 - 06-12-2017, 08:16 AM
RE: Pine64 Head Unit - by dikov - 06-12-2017, 09:19 AM
RE: Pine64 Head Unit - by amir.movafagh - 01-30-2018, 03:00 AM
RE: Pine64 Head Unit - by Nilda - 04-08-2019, 03:55 AM
RE: Pine64 Head Unit - by rogatip79 - 11-19-2019, 04:35 AM
  Pine64 as squeezebox touch replacement Learnincurve 12 28,110 01-13-2021, 02:11 AM
Last Post: Learnincurve
  Pine64 E-ink screen - Android projectileobjects 4 9,655 12-03-2020, 03:03 PM
Last Post: Silk
  Pine64 based IP KVM tuaris 0 3,982 08-06-2020, 12:05 AM
Last Post: tuaris
  PINE64 to allow use of SATA disk on network/FTP mwelbourne 10 15,759 11-18-2019, 04:09 PM
Last Post: evilbunny
  How to setup VNC on your Pine64 (Debian, SSH, headless) pine64nutz 20 42,876 04-16-2019, 08:00 AM
Last Post: hg6806
  Setup Pine64+ with OP-TEE stdys 0 3,559 09-13-2018, 03:23 PM
Last Post: stdys
Information UEFI for Pine64 z4v4l 20 38,261 06-24-2018, 03:06 PM
Last Post: z4v4l
  Domoticz + PINE64 Z-Wave Module + Open Z-Wave klliew 4 9,755 04-19-2018, 02:23 AM
Last Post: Harlan Mueller
  Pine64 as Security Camera / Baby Monitor utdrmac 2 7,167 02-01-2018, 07:49 AM
Last Post: davidbrucs
Photo Nextcloud running on Pine64 gbjensen 1 6,072 01-18-2018, 05:51 AM
Last Post: Luke
