Android 7.1 Tablet and TV (alpha, proposal)
#20
(05-27-2017, 06:50 AM)simplexdan Wrote:
(05-22-2017, 04:01 PM)drich Wrote: Hi, I can't get the LCD to work, using the 2GB pine64.
I set screen0 to "lcd" and mode to "screen0" only. When I power up the pine, the LCD lights up a few seconds later then everything instantly shuts off, pine's power led turn off and LCD is totally black. (compiled from clean sources, and the image works correctly on HDMI with screen0=hdmi)
Is there any logging somewhere to see what happens ?
There are a ton of threads for this. Not only are they sending some updates the kill the build, it also could be something as simple as your power supply and how your attaching it to the board....
My LCD worked fine with the old builds, but I will give a try with 5.1 image to be sure that it's not a hardware fault.
Edit: okay looks like my lcd is defective, I just discovered that I have to touch the GPIOs with my hand to turn on the display, touch-layer is not working at all
Edit2: the ribbon cable of the panel is actually cut on one side, probably the backlight part
RE: Android 7.1 Tablet and TV (alpha, proposal) - by drich - 05-27-2017, 07:37 AM
  Android 6.0 Tablet and TV (release candidate, maintained) ayufan 228 389,890 12-29-2020, 01:13 AM
Last Post: firmwarefile
Shocked Remote for Android? liodra 18 29,837 12-23-2020, 06:11 AM
Last Post: Learnincurve
  Adding an accelerometer to Android modsbyus 11 16,895 11-02-2020, 08:12 PM
Last Post: Little_Johnny
  Android Things OS dqvsra 2 7,008 12-03-2019, 09:52 AM
Last Post: hangglider
  Is there another link for Android images? Maalth 3 7,083 10-10-2019, 07:57 AM
Question Android SDK Oreo NGC6691 2 5,633 07-15-2019, 08:29 PM
Last Post: dazza5000
  Putting Android 9 RockPro64 source into easier to manage repositories dazza5000 0 3,356 07-15-2019, 08:29 PM
  Android 5.1.1 TV (old-stable, no longer maintained) ayufan 194 259,764 03-12-2019, 04:53 PM
Last Post: neosapien
  Issues with SD Card and Running Android Twistedx 0 3,560 02-26-2019, 11:58 AM
Last Post: Twistedx
  Android 7.1 (PINE A64(+)) pineadmin 59 105,701 02-10-2019, 07:44 PM
Last Post: mmmarcus
