Playbox battery charge
(10-21-2016, 05:13 AM)jdmwrx94 Wrote: yes it think this will help.  I do have a 2wire battery. i need to solder a 10kohm resistot between àin 2 and 3 to fake the temp sensor?
Yes, you will require a 10K ohm pulldown resistor running from the second (middle) pin of the battery connector to ground;  otherwise, the battery will not charge.
Playbox battery charge - by jdmwrx94 - 10-20-2016, 07:42 PM
RE: Playbox battery charge - by Bluphire - 10-20-2016, 10:32 PM
RE: Playbox battery charge - by jdmwrx94 - 10-21-2016, 05:13 AM
RE: Playbox battery charge - by MarkHaysHarris777 - 10-21-2016, 05:44 AM
RE: Playbox battery charge - by jdmwrx94 - 10-23-2016, 07:41 AM
RE: Playbox battery charge - by pfeerick - 10-23-2016, 11:01 PM
RE: Playbox battery charge - by Pineplayer - 10-28-2016, 11:13 AM
RE: Playbox battery charge - by PakenPine - 10-31-2016, 01:42 PM
RE: Playbox battery charge - by pfeerick - 10-31-2016, 06:30 PM
RE: Playbox battery charge - by pfeerick - 12-06-2016, 07:49 PM
RE: Playbox battery charge - by Toriless - 12-20-2016, 07:19 AM
  Playbox with DAC llungster 0 2,743 04-02-2019, 09:02 AM
Last Post: llungster
  playbox case ribbon cable too short pinoosh 7 12,399 02-22-2019, 03:24 AM
Last Post: GaryFunk
Information Giving the Pine a trunk, a Playbox pedestal tommypine 7 10,209 07-16-2017, 01:51 AM
Last Post: selina3
Rainbow (Cluster) Modified Playbox Enclosure Progress predominant 3 5,488 06-17-2017, 01:29 AM
Last Post: pfeerick
  playbox and camera jpfaubert 1 3,831 03-07-2017, 12:51 AM
Last Post: MarkHaysHarris777
  How is the battery Supposed to be mounted in the PlayBox enclosure? dbarbee 2 5,726 02-12-2017, 10:17 PM
  Playbox case orderable? schindlb 8 13,697 10-02-2016, 08:20 AM
Last Post: schindlb
  Solution to awkward playbox cabling Visionrx7 2 4,287 09-13-2016, 11:46 PM
Last Post: Visionrx7
  Question regarding Playbox case jeffrey_ring 3 5,340 09-13-2016, 07:39 PM
  ABS Playbox came with no extension cable? kenhawkins 4 6,302 09-12-2016, 02:47 PM
Last Post: echild
