Enclosure issue
(09-03-2016, 10:49 PM)MarkHaysHarris777 Wrote: hi pfeerick,  the large opening in the side is clearly there to facilitate access to the audio jack, the system|charge LEDs and the switches...  see the link below, there is a pic about half way down.
http://forum.pine64.org/showthread.php?tid=2106
Also, I suspect that a cover plate was initially designed which is missing (but of course I really don't know).
Ah... ok... I'm thinking of the wrong case then... I'm thinking of the ABS enclosure, not the Playbox (which is one pictured in that thread). Thanks for that Marcus.
It looks like the ABS enclosure suffers from the same problem though... as the fifth picture down in the kickstarter update linked in that other thread (which is of the ABS case) also shows a cutout on the end. So unless the end has the reciprocal bit to fill the gap, it looks like even that case is a bit wonky... as from what you can see of the photo, the base has the cutout also.
I had a look at the STL files since they were linked that update, and it looks like they decided to simply use a block cutout, as there's also no provision at all for an piece to fill the gap, as there's no anchor points for it. Strange too, as they had to modify the plastic lip on the lid of the playbox to make way for the height of the USB ports..., and there's a place-holder for the pine64 in the model, so it was a deliberate design choice... wonder if they just took the easy way out, or were thinking along the lines of not sealing it completely to allow for at least *some* limited airflow?
Enclosure issue - by gates_c - 08-31-2016, 02:12 PM
RE: Enclosure issue - by mldavies - 09-03-2016, 10:21 AM
RE: Enclosure issue - by dedgar - 09-03-2016, 09:29 PM
RE: Enclosure issue - by pfeerick - 09-03-2016, 10:33 PM
RE: Enclosure issue - by MarkHaysHarris777 - 09-03-2016, 10:49 PM
RE: Enclosure issue - by pfeerick - 09-04-2016, 11:03 PM
RE: Enclosure issue - by jhg03a@acu.edu - 09-07-2016, 05:34 PM
RE: Enclosure issue - by dedgar - 09-08-2016, 08:12 AM
RE: Enclosure issue - by jhg03a@acu.edu - 09-08-2016, 08:27 AM
RE: Enclosure issue - by MarkHaysHarris777 - 09-08-2016, 08:38 AM
RE: Enclosure issue - by leon.stankowski - 09-14-2016, 03:09 PM
RE: Enclosure issue - by FrenchFrog - 09-15-2016, 07:44 AM
RE: Enclosure issue - by matteus - 09-15-2016, 10:38 AM
RE: Enclosure issue - by pfeerick - 09-15-2016, 06:29 PM
Video 7" LCD wooden framen enclosure for Pine64 *UPDATED WITH killor 12 19,940 10-12-2018, 03:08 PM
Lightbulb Perfect ABS Plastic Server Enclosure from Radio Shack MarkHaysHarris777 14 34,153 09-11-2017, 11:39 AM
Last Post: stuartiannaylor
Rainbow (Cluster) Modified Playbox Enclosure Progress predominant 3 5,480 06-17-2017, 01:29 AM
Last Post: pfeerick
  Nostalgic enclosure VHS carlo318 4 7,539 03-05-2017, 04:56 PM
Last Post: carlo318
  How is the battery Supposed to be mounted in the PlayBox enclosure? dbarbee 2 5,719 02-12-2017, 10:17 PM
  Enclosure for flush-mounting the 7" touchscreen Learnincurve 9 13,008 02-07-2017, 08:45 PM
Last Post: Bluphire
  Official C4 Labs LCD Enclosure *UPDATED WITH ASSEMBLY VIDEO* Bluphire 12 24,985 01-06-2017, 03:15 AM
Last Post: Learnincurve
  Tablet Enclosure Vachtra 11 19,996 12-20-2016, 07:17 AM
Last Post: Toriless
Rainbow PineA64 Home-Brew card-board Play Box for Android & LCD Enclosure MarkHaysHarris777 9 19,035 11-01-2016, 06:23 PM
  White box plastic enclosure clawinus 3 6,627 10-13-2016, 08:47 AM
Last Post: Bluphire
