No IMG file after extracting Android dd
(08-05-2016, 08:14 AM)MarkHaysHarris777 Wrote:
(08-05-2016, 08:09 AM)tomwjr Wrote:
(08-05-2016, 08:04 AM)MarkHaysHarris777 Wrote:
(08-05-2016, 07:38 AM)tomwjr Wrote:
(08-04-2016, 11:59 PM)MarkHaysHarris777 Wrote: MarkHaysHarris777How embarrassing, and how funny; really.
Where did you pull the image from ?  We'll fix it...
Android 5.1.1 Image (HDMI Video Output) Release 20160711
It was the 8GB non-rooted version.
DD images:
Thank you, we'll look into it.  something is goofy because what you're looking at is more or less normal, but you should not be able to mount it and see it in windoze;  how did you produce your pic?
Thanks.
That is a screenshot of my windows explorer after extracting the file with 7-Zip. I've downloaded and extracted it a couple of times, and that's what I get each time. No IMG file, just the folders and files you see in the screenshot.
Thank you, definitely we will look into this !
Thank you, I appreciate it. Just as an FYI, I just downloaded and extracted the previous 8GB Version and it extracted to an IMG file just fine.
RE: No IMG file after extracting Android dd - by tomwjr - 08-05-2016, 08:27 AM
Question Do I need a touchscreen to run Android? chrbar 3 5,156 08-08-2018, 10:55 PM
Last Post: chrbar
  ethernet lan speed problem android fulltone 0 2,640 04-23-2018, 01:47 AM
Last Post: fulltone
  No sound on Android 6 or 7.1 reeno 0 2,928 07-29-2017, 06:31 PM
Last Post: reeno
  Android pretty slow Passiday 2 5,068 10-08-2016, 03:46 AM
Last Post: Passiday
  Can't make the Android image boot Passiday 3 5,509 10-07-2016, 09:34 AM
Last Post: Passiday
  LCD screen with android, runs fine, screen does not turn back on..? GhostlyAspens 2 4,275 09-01-2016, 12:24 AM
Last Post: GhostlyAspens
  Can't get past the "Allwinner/Android" screen d34532 2 5,118 07-10-2016, 08:21 PM
Last Post: d34532
Thumbs Down Issues with Android mliebski 0 2,016 07-01-2016, 11:14 AM
Last Post: mliebski
  Android Touchscreen/HDMI Severian 2 5,097 06-18-2016, 03:28 PM
Last Post: Severian
  Android: Works on monitor but not on HDTV wickemt 2 4,803 06-13-2016, 09:54 AM
Last Post: wickemt
