[PineTab2] Issues with Mobian Networking
(09-02-2023, 07:06 AM)lllll Wrote: @Cornelia Xaos
please don't give up! I got my PineTab2 recently and had pretty much the same problem (but another wifi adapter).
I'm not involved in development at all, so what I'm posting here is not a definitive guide, but I asked in mobian matrix/irc channel and Julian helped me out with these steps:
Quote:Please enable the staging repository by adding
deb http://repo.mobian.org/ staging main
to the /etc/apt/sources.list.d/mobian.list file, then run
sudo apt update && sudo apt install linux-image-6.4-rockchip
, and finally, reboot. Your adaptor should then be working.
You will actually also have to add non-free-firmware at the end of the deb http://repo.mobian.org trixie main line in the /etc/apt/sources.list.d/mobian.list file, and run sudo apt update && sudo apt install firmware-realtek. So, if you haven't already done that, it makes sense to modify the file once, add both things, then run sudo apt update && sudo apt install firmware-realtek linux-image-6.4-rockchip, before then rebooting. That way, everything is done at once.
If you are wondering how to update without working wifi, you can follow this link for connection sharing from your PC via USB https://wiki.mobian-project.org/doku.php...pc-via-usb
Again, I'm not involved in mobian, so these instructions might be already outdated, but I'm sure they are happy to help
It works for me, but the package linux-image-6.4-rockchip doesn't exist. I've installed linux-image-6.6-rockchip instead.
#!/bin/bash
# System update
sudo apt update -y && sudo apt upgrade -y
#(Optional) USB WiFi drivers
sudo echo "deb http://repo.mobian.org/ staging main non-free-firmware" | sudo tee -a /etc/apt/sources.list
sudo apt install linux-image-6.6-rockchip
RE: [PineTab2] Issues with Mobian Networking - by riot - 10-16-2023, 08:47 AM
  PineTab2 corrupted EMMC explit 5 1,364 03-27-2024, 04:56 PM
Last Post: oiyounutter
Video Pinetab2 camera drivers cringeops 9 1,321 03-18-2024, 11:40 AM
Last Post: cringeops
  eMMC backup - pinetab2 pinetar.gz 0 536 01-07-2024, 09:08 PM
Last Post: pinetar.gz
  Mobian Boot Problem rogerwegmann 14 4,375 12-13-2023, 11:04 AM
Last Post: diederik
  Mobian won't boot after ton of updates bartgrefte 11 5,256 12-10-2023, 02:47 AM
Last Post: bartgrefte
  Touch doesnt rotate on Sway in PineTab2 cgbarros 4 2,228 08-03-2023, 05:49 PM
Last Post: cgbarros
  Disabling PineTab2 physical keyboard and touchpad? johns 7 2,042 08-03-2023, 11:55 AM
Last Post: cgbarros
  Will sudo pacman -Syu brick the PineTab2? cgbarros 10 3,035 07-24-2023, 01:15 PM
Last Post: rqkeating
  Mobian - Phosh frtodd 1 1,298 06-18-2023, 04:51 AM
Last Post: GloriousCoffee
  Udemy not working on pinetab2 (danctnix) jbreese 3 1,244 06-13-2023, 11:34 AM
Last Post: jbreese
