Steps for Installing Alternative OSes in 2022
Err, #4 will work, just not very convenient. the netbsd will have a uboot in the 1st 16M
(to disable you have to unnecessisarily remove and then re-install back cover, why is there not a hole?))
#5 save emmc mbr, save emmc 1st 16M, blank 1st 16M. restore mbr
Then only the uboot on SD is available, and then you can actually evaluate a SD uboot
How to boot from emmc then? either tow-boot on SD (+ whatever distro) OR
Just a uboot on a preferably small SD, the rest can be a data drive
Do put a file system on the rest, or uboot will freak out, lock up
A good way to test uboots
And, BTW, if you have a working uboot, DON'T be in a hurry to update it,
ask yourself ,,,,WHY (and make a backup, so you can change your mind)
BTW, be aware that, for rk3399, uboot on SPI is DIFFERENT than uboot on SD/emmc,m,,,, use right one
RE: Steps for Installing Alternative OSes in 2022 - by wdt - 11-12-2022, 09:17 AM
  Partial boot after installing Manjaro on emmc regivanx 11 3,338 02-06-2023, 09:11 AM
  Installing Debian using files only from debian.org and encrypted root filesystem omarcomputing 0 803 10-08-2022, 11:03 AM
Last Post: omarcomputing
  Mid 2022: what is in your humble opinion the best working OS for the PinePro? walterbe 3 2,448 06-29-2022, 02:00 PM
Last Post: Chief
  Pinebooks in the news (27 February 2022) sandspur 0 1,098 02-27-2022, 09:25 AM
Last Post: sandspur
  Installing Archlinux try2bgr8 1 2,361 10-27-2020, 07:14 PM
  OBS Studio or alternative on Pinebook Pro? charlespine 4 6,446 09-26-2020, 07:59 AM
Last Post: khan
  trouble with installing emacs Corey_R 1 2,528 09-14-2020, 08:24 PM
Last Post: carlosqueso
Question How far are we from installing Linux witout extra patches? dumetrulo 1 2,382 06-04-2020, 09:43 AM
Last Post: xmixahlx
  My pinebook Pro does not turn on after installing Manjaro 20.02 kde iamnotapenguin 9 10,966 05-08-2020, 10:26 PM
Last Post: iamnotapenguin
  Alternative to the screws? MIchael 10 13,060 03-12-2020, 08:46 AM
Last Post: ab1jx
