Suggested software for use case
(08-17-2022, 12:58 AM)LivingLinux Wrote:
(08-16-2022, 07:48 PM)ehcorn Wrote: Hi all, I just got my pinebook pro and it’s really interesting, but I’ve run into some issues installing software I had intended to use. I’m planning on using this for mobile writing and I need a reference manager and writer installed. I usually use zotero but it’s missing arm64 support, I also use obsidian and zettlr which both have arm64 app images I can use but app images seem less “good” than a full install but I don’t really know better or much about them!
Zotero and zettlr are available in the Arch User Repository (AUR).
Not sure if it compiles.
Looks like you have the change the PKGBUILD file to enable aarch64.
Here you can see how to do that: https://youtu.be/y9XHQCXhGX4
I was trying to figure this out last night, thanks!
Sent from my iPhone using Tapatalk
Suggested software for use case - by ehcorn - 08-16-2022, 07:48 PM
Suggested software for use case - by ehcorn - 08-17-2022, 08:08 AM
Suggested software for use case - by ehcorn - 08-17-2022, 03:44 PM
RE: Suggested software for use case - by TRS-80 - 08-17-2022, 04:06 PM
  Kdenlive or other video editing software?? SuttonWillow 4 4,651 05-26-2022, 09:11 PM
Last Post: IsraelRobinson
  How Much Non-Free Software Does The PineBook Pro Use? ImmyChan 6 4,855 02-18-2021, 07:58 PM
Last Post: TRS-80
  Screws on bottom case coming loose quadrantids 8 7,346 01-20-2021, 03:47 AM
Last Post: quadrantids
  Kdenlive or other video editing software? ImmyChan 2 2,934 01-19-2021, 01:12 AM
  Pinebook Pro Case models sundog 2 2,869 11-05-2020, 09:31 AM
Last Post: sundog
  Minor case damage with gentle use. (Is anyone else seeing this?) hikaricore 31 35,514 10-26-2020, 10:19 PM
Last Post: hikaricore
  Got a case for my Pinebook Pro GhostDragon 3 4,269 09-24-2020, 07:24 PM
Last Post: bastafari
  Case defect (crack) bigCamel 25 24,967 08-18-2020, 03:41 PM
Last Post: bigCamel
  Case upgrade for my PBP robt 2 3,878 08-08-2020, 04:35 PM
Last Post: Damon
Photo No case logo? No problem! ALBNC1974 6 7,657 06-04-2020, 07:48 PM
Last Post: Dendrocalamus64
