SSH from Windows PC into PinePhone?
Thanks, Wibble
1. The example here shows how to start Firefox to Forward X11 Display to Windows using Putty:
https://manjaro.site/how-to-forward-x11-...ing-putty/
2. The Youtube video shows how to run LibreOffice by X11 Forwarding using Putty on Windows, and is very detailed.
https://www.youtube.com/watch?v=QRsma2vkEQE
a) We installed the Xming Windows applications, which allows to configure PuTTY.
b) In Putty, there was the option to activate  Forward X11, as described in 1)
c) then, we started in PuTTY a terminal on the PinePhone as described in 1)
d) We then typed «Firefox» in the command line of the Pinephone and return:
result:
no DISPLAY environment variable specified
e) We then typed «libreoffice –writer » in the command line of the Pinephone and return:
result:
Failed to open display
On the Windows PC, whe have two icons after installation of Xming: Xming and Xlaunch.
- With Xming, PuTTY can be configured to support X11 Forwarding
- With  Xlaunch, nothing happend.
In example 1, Firefox started in the PuTTY terminal on the Windows PC
In example 2, LibreOffice started in the PuTTY terminal on the Windows PC
In our example, nothing started in the PuTTY terminal on the Windows PC.
RE: SSH from Windows PC into PinePhone? - by Peter Gamma - 06-09-2022, 03:25 AM
  PinePhone - boot from microSD laserpyramid 7 623 04-25-2024, 05:56 AM
Last Post: aular
  pinephone virtual keyboard aular 4 367 04-10-2024, 03:45 PM
Last Post: aular
  PinePhone Doesn't Boot LED Doesn't Show Any Signs When Charging dorkydev 1 246 04-02-2024, 11:50 AM
  Are you using the Pinephone as your daily driver? jro 157 109,609 02-18-2024, 11:33 PM
Last Post: aular
  2020 PinePhone Manjaro CE EU for sale, name your price astrojuanlu 7 1,855 02-14-2024, 04:51 PM
Last Post: astrojuanlu
  pinephone is not bootble for the box. ijij 1 624 01-19-2024, 01:29 PM
Last Post: fxc
  Multiple issues with the Pinephone MTXP 12 2,411 12-28-2023, 07:55 AM
Last Post: MTXP
  pinephone repair shop shengchieh 0 510 12-26-2023, 02:42 PM
Last Post: shengchieh
  sudo nano file saving pinephone beta edition CharlesGnarley 4 1,732 12-22-2023, 03:44 PM
  Can't get Mobian on PinePhone to recognise USB-C docking bar duncan_bayne 9 7,001 12-04-2023, 02:14 AM
Last Post: Peter Gamma
