How is youtube and general web browsing on the PineBook Pro?
(05-31-2022, 02:21 PM)catloaf Wrote:
(05-29-2022, 05:29 PM)tmschmitz Wrote: I use my pinebook pro as a daily driver. I have had no issues with 1080p in mpv, although I usually opt for 720p to save space. I hadn't tested anything higher, or youtube in chromium ( I typically run a fairly tied down firefox with noscript, and open videos in mpv ), but but your query made me curious, so I found an HD video on youtube in chromium, and tried it in 1080p, 1440p, and 2160p. 1080p and 1440p worked fine, with only one or two pauses right at the start, then all went smoothly and looked nice. 2160 was unbearable with all the hiccups and stalls. In mpv at 2160 it was noticible, but bearable.
Does stats for nerds show any dropped frames? Also what is cpu usage like, basically is it hardware accelerated?
Youtube's vp9 codec is not hw accelerated and drops a lot a frames, there are extensions that will disable this codec however.
With other codecs you get a few dropped frames, but nothing major (tested on 720p@60 avc1)
Like the person above also mentioned, you can also use mpv and ytdl to stream videos with no dropped frames and generally better load times.
general web browsing is a breeze for me but I do not visit particularly intense websites. I have found that things such as webmail and blogs work perfectly fine. Sites with heavy javascript such as news websites or social media platforms are sluggish but using a content blocker already helps with that.
RE: How is youtube and general web browsing on the PineBook Pro? - by user18130814200115 - 06-02-2022, 06:15 AM
  Pinebook Pro Initial Impressions kunger 443 599,605 04-16-2024, 07:29 PM
  looking to buy one pinebook pro (mainland China) duanduan 3 2,395 03-21-2024, 07:44 PM
Last Post: wangyukunshan
  Cellular module for Pinebook Pro Lotech 1 467 03-05-2024, 05:40 AM
  Screen on pinebook stays black but can ssh into machine tuxxpine 0 347 02-23-2024, 04:22 PM
Last Post: tuxxpine
  Sale my ANSI PineBook Pro cuthbertdavies 0 336 02-14-2024, 09:12 PM
Last Post: cuthbertdavies
  Compiling with -j6 on the Pinebook Pro (Overheat) KC9UDX 0 268 02-14-2024, 09:01 AM
  Pinebook Pro in EU for Sale - €90 jan_vdk 2 750 02-07-2024, 02:12 AM
Last Post: 23Ro
  Pinebook Pro for sale tomekdev 2 825 02-01-2024, 11:35 AM
Last Post: tomekdev
  Video Editing Is Possible On The PineBook Pro! ImmyChan 10 7,825 12-17-2023, 09:29 PM
Last Post: insideau786
  Brand new Pinebook Pro doesn't boot after Manjaro update johnboiles 8 2,407 12-15-2023, 02:11 PM
