Pinebook Pro not turn
(03-11-2022, 02:05 AM)wdt Wrote: Since  from your OP, you have had the back off, measure the battery voltage
It should be in the range 3.6V to 4.2V, it likely will be lower
Gently charge battery, 100ma @4.2V until battery reaches 3.6+V
Maybe a old phone charger (5V) and 5-10 ohm resistor
Old in that it has low ma output, the specs are always on the label
Use the cable off, say a dead mouse, the wires inside are always colour coded,
i've never seen them wrong, but you might check
OR
try the 1/2 hour charge, unplug,replug another 1/2 hour and so on
The timer resets with each power supply activation
This, BTW is normal for lithium chargers
Grazie, ora proverò anche questa cosa.
Il problema è che non si accende neanche escludendo la batteria e collegando i 2 cavi che sono all'interno del case e poi collegandolo al barilotto.
Thanks, now I'll try this too. The problem is that it does not turn on even excluding the battery and connecting the 2 cables that are inside the case and then connecting it to the barrel.
Pinebook Pro not turn - by carbo29 - 03-09-2022, 12:48 PM
RE: Pinebook Pro not turn - by josmo - 03-10-2022, 11:48 AM
RE: Pinebook Pro not turn - by tophneal - 03-10-2022, 01:04 PM
RE: Pinebook Pro not turn - by wdt - 03-10-2022, 11:19 PM
RE: Pinebook Pro not turn - by carbo29 - 03-11-2022, 12:47 AM
RE: Pinebook Pro not turn - by wdt - 03-11-2022, 02:05 AM
RE: Pinebook Pro not turn - by carbo29 - 03-11-2022, 02:20 AM
RE: Pinebook Pro not turn - by carbo29 - 03-11-2022, 05:18 AM
RE: Pinebook Pro not turn - by wdt - 03-11-2022, 12:21 PM
RE: Pinebook Pro not turn - by carbo29 - 03-11-2022, 01:06 PM
RE: Pinebook Pro not turn - by wdt - 03-11-2022, 10:41 PM
RE: Pinebook Pro not turn - by carbo29 - 03-12-2022, 12:42 PM
  Pinebook Pro Initial Impressions kunger 443 588,341 04-16-2024, 07:29 PM
  looking to buy one pinebook pro (mainland China) duanduan 3 2,293 03-21-2024, 07:44 PM
Last Post: wangyukunshan
  Cellular module for Pinebook Pro Lotech 1 399 03-05-2024, 05:40 AM
  Screen on pinebook stays black but can ssh into machine tuxxpine 0 302 02-23-2024, 04:22 PM
Last Post: tuxxpine
  Sale my ANSI PineBook Pro cuthbertdavies 0 292 02-14-2024, 09:12 PM
Last Post: cuthbertdavies
  Compiling with -j6 on the Pinebook Pro (Overheat) KC9UDX 0 227 02-14-2024, 09:01 AM
  Pinebook Pro in EU for Sale - €90 jan_vdk 2 675 02-07-2024, 02:12 AM
Last Post: 23Ro
  Pinebook Pro for sale tomekdev 2 741 02-01-2024, 11:35 AM
Last Post: tomekdev
  Video Editing Is Possible On The PineBook Pro! ImmyChan 10 7,611 12-17-2023, 09:29 PM
Last Post: insideau786
  Brand new Pinebook Pro doesn't boot after Manjaro update johnboiles 8 2,231 12-15-2023, 02:11 PM
