Needed -- Clarification of Boot SequenceInstructions
(03-04-2022, 12:13 PM)fxc Wrote: The boot order paragraph was containing outdated information, I've updated it and removed apparently confusing details.
As this is your second forum post here now (why does it need a second one?), can you clarify what your exact question is? You're expressing general confusion but it is impossible to answer your questions if you don't say where the issue is.
There are two questions because they are different queries.
Can the wiki now be interpreted to read that the pre-flashed install boots by default from eMMC not SD?  Does not say so specifically.  If so, thanks for the clarification.
Down below, wiki still says: "Due to the specific boot order it is currently strongly recommended to boot from the microSD card only. Please ask in the community chat if you have any questions regarding the installation"
Is this still in play? Also, why is it strongly recommended to boot from SD?
RE: Needed -- Clarification of Boot SequenceInstructions - by tckosvic - 03-04-2022, 01:57 PM
  Can't boot Pinephone Pro into Factory Test Build for Hardware Checking jydoxcen 3 836 02-17-2024, 04:04 AM
Last Post: fxc
  Mobian + tow boot + emmc flash = boot loop spropine 4 3,289 12-31-2022, 09:14 AM
Last Post: mburns
  Need to re-write U-boot from Pinephone pro currently in mass rom mode wolverine1 6 2,984 11-20-2022, 05:58 AM
Last Post: wibble
  Tow-Boot issue Barugon 1 1,386 10-22-2022, 03:22 AM
Last Post: AndrewBlackmiller
  pinephone pro boot: kernel image not aligned on 64k boundary kmerfeld 2 2,087 08-15-2022, 10:35 AM
Last Post: ajaso
  pinephone pro don’t boot anymore :/ (I erased bootloader by mistake) elode 9 5,008 06-20-2022, 11:16 AM
Last Post: elode
Information Fix PinePhone Pro when unable to boot due to drained battery butjar 7 6,080 05-21-2022, 01:24 PM
Last Post: 98cwitr
  My new Pinephone Pro does not boot any more jlioret 3 2,621 05-21-2022, 12:08 PM
Last Post: 98cwitr
  Tow-Boot on PP vasir 1 1,315 04-28-2022, 05:22 PM
Last Post: vasir
  Boot order Barugon 13 8,160 03-11-2022, 09:16 AM
Last Post: kaida
