01-31-2022, 11:46 AM
(01-29-2022, 09:36 AM)codefossa Wrote: I'm using Manjaro Phosh linked from here: https://wiki.pine64.org/wiki/PinePhone_P...anjaro_ARM
It was running fine, but this morning I ran an update and now cannot boot. I did receive an error with initcpios, and uboot was updated as well. I'll paste the update output below.
When I boot, I get a red light then it turns yellow(?). If I put my hand near it, I see red, yellow, and green light. Nothing displays on the screen, and I cannot seem to boot into either the system or SD card.
Code::: Starting full system upgrade...
resolving dependencies...
looking for conflicting packages...
Packages (11) alsa-card-profiles-1:0.3.44-1 gst-plugin-pipewire-1:0.3.44-1 libpamac-11.2.0-5 linux-pinephonepro-5.16.3-1 mesa-21.3.5-1.1 phoc-0.12.0-2
phosh-0.15.0+13+g1ad304a-1 pipewire-1:0.3.44-1 pipewire-alsa-1:0.3.44-1 pipewire-pulse-1:0.3.44-1 uboot-pinephonepro-3:2021.07-1
Total Download Size: 33.17 MiB
Total Installed Size: 114.54 MiB
Net Upgrade Size: -0.14 MiB
:: Proceed with installation? [Y/n]
:: Retrieving packages...
libpamac-11.2.0-5-aarch64 846.0 KiB 583 KiB/s 00:01 [#######################################################] 100%
phosh-0.15.0+13+g1ad304a-1-aarch64 577.8 KiB 362 KiB/s 00:02 [#######################################################] 100%
pipewire-1:0.3.44-1-aarch64 1336.1 KiB 689 KiB/s 00:02 [#######################################################] 100%
phoc-0.12.0-2-aarch64 484.1 KiB 846 KiB/s 00:01 [#######################################################] 100%
uboot-pinephonepro-3:2021.07-1-aarch64 397.9 KiB 524 KiB/s 00:01 [#######################################################] 100%
pipewire-pulse-1:0.3.44-1-aarch64 136.8 KiB 233 KiB/s 00:01 [#######################################################] 100%
gst-plugin-pipewire-1:0.3.44-1-aarch64 40.1 KiB 124 KiB/s 00:00 [#######################################################] 100%
alsa-card-profiles-1:0.3.44-1-aarch64 26.2 KiB 81.8 KiB/s 00:00 [#######################################################] 100%
pipewire-alsa-1:0.3.44-1-aarch64 4.5 KiB 14.9 KiB/s 00:00 [#######################################################] 100%
mesa-21.3.5-1.1-aarch64 15.5 MiB 2.52 MiB/s 00:06 [#######################################################] 100%
linux-pinephonepro-5.16.3-1-aarch64 13.9 MiB 2.03 MiB/s 00:07 [#######################################################] 100%
Total (11/11) 33.2 MiB 4.76 MiB/s 00:07 [#######################################################] 100%
(11/11) checking keys in keyring [#######################################################] 100%
(11/11) checking package integrity [#######################################################] 100%
(11/11) loading package files [#######################################################] 100%
(11/11) checking for file conflicts [#######################################################] 100%
(11/11) checking available disk space [#######################################################] 100%
:: Processing package changes...
( 1/11) upgrading alsa-card-profiles [#######################################################] 100%
( 2/11) upgrading pipewire [#######################################################] 100%
New optional dependencies for pipewire
pipewire-x11-bell: X11 bell
realtime-privileges: realtime privileges with rt module
rtkit: realtime privileges with rtkit module [installed]
( 3/11) upgrading mesa [#######################################################] 100%
( 4/11) upgrading gst-plugin-pipewire [#######################################################] 100%
( 5/11) upgrading libpamac [#######################################################] 100%
( 6/11) upgrading linux-pinephonepro [#######################################################] 100%
( 7/11) upgrading pipewire-alsa [#######################################################] 100%
( 8/11) upgrading pipewire-pulse [#######################################################] 100%
( 9/11) upgrading phoc [#######################################################] 100%
(10/11) upgrading phosh [#######################################################] 100%
(11/11) upgrading uboot-pinephonepro [#######################################################] 100%
Re-generating U-Boot boot script /boot/boot.scr... done.
Flashing U-Boot components... done.
Required U-Boot components flashed to /dev/mmcblk2 successfully.
Please reboot your phone for the changes to take effect.
:: Running post-transaction hooks...
( 1/10) Reloading system manager configuration...
( 2/10) Reloading device manager configuration...
( 3/10) Arming ConditionNeedsUpdate...
( 4/10) Updating the MIME type database...
( 5/10) Updating module dependencies...
( 6/10) Updating linux-pinephonepro module dependencies...
( 7/10) Updating linux-pinephonepro initcpios...
==> Building image from preset: /etc/mkinitcpio.d/linux-pinephonepro.preset: 'default'
-> -k 5.16.3-1-MANJARO-ARM -c /etc/mkinitcpio.conf -g /boot/initramfs-linux.img
==> Starting build: 5.16.3-1-MANJARO-ARM
-> Running build hook: [base]
-> Running build hook: [udev]
-> Running build hook: [bootsplash-manjaro]
-> Running build hook: [autodetect]
-> Running build hook: [modconf]
-> Running build hook: [block]
-> Running build hook: [filesystems]
-> Running build hook: [keyboard]
-> Running build hook: [fsck]
==> ERROR: module not found: `panel_edp'
==> WARNING: No modules were added to the image. This is probably not what you want.
==> Creating gzip-compressed initcpio image: /boot/initramfs-linux.img
==> WARNING: errors were encountered during the build. The image may not be complete.
error: command failed to execute correctly
( 8/10) Reloading system bus configuration...
( 9/10) Compiling GSettings XML schema files...
(10/10) Updating the desktop file MIME type cache...
There are apparently two contacts on the motherboard (I believe they're labeled DIS eMMC) that you have to short in order to bypass eMMC and boot from the SD card.
