How to mainline kernel on daniel thompson's debian installer?
The bottom line is to find the proper initramfs configuration matching the actual hardware.
Try configuring the initramfs to be build with "most" modules.
While this creates a huge initramfs file, chances are it contains all needed to boot normally.
Once booted, create a listing of all loaded modules with the lsmod command and use that to tune the actual initramfs build.
That's the way i managed to create a suitable initram configuration.
See https://forum.pine64.org/showthread.php?tid=15031 for the result.
Devices: Pinebook Pro & Pinephone (Braveheart)
RE: How to mainline kernel on daniel thompson's debian installer? - by vajak - 11-08-2021, 07:47 PM
  Debian on Pinebook Pro u974615 7 1,195 03-31-2024, 10:11 AM
Last Post: u974615
  install debian on pbp jsch 7 4,130 11-22-2023, 04:22 PM
Last Post: TRS-80
  Unable to install Debian Bullseye because of missing wifi firmware Pino64 7 4,118 07-15-2023, 02:58 PM
Last Post: u974615
  kernel module that supports usb-c hdmi alexandre 16 14,745 05-14-2023, 09:58 PM
Last Post: rathofkhan3
Question Debian (Vanilla) no output on display after Kernel update (6.0.8-1) as365n4 1 1,294 12-09-2022, 12:43 PM
Last Post: as365n4
  Unsuccessful using danielt's unofficial Debian installer on the PBP joeDoe 2 2,364 12-09-2022, 05:04 AM
Last Post: ndp
  How can I install Debian? ImmyChan 1 2,068 10-19-2022, 03:09 AM
Last Post: alpopa
  newer ""emmc-installer" images (manjaro xfce) magistral 1 1,125 10-10-2022, 06:22 AM
Last Post: maxjrh
  when i close my laptop lid the screen doesn't turn on? (debian bullseye based) computerc 3 1,931 09-23-2022, 08:37 PM
Last Post: computerc
  Debian emmc installer db579 6 3,029 08-23-2022, 06:13 AM
Last Post: db579
