double tap to wake support
If I understood Ondřej's blog post correctly, this might currently not be possible to do:
2021–10–18: Pinephone Pro – support merged into my kernel tree Wrote:
  • And that was another issue. Power consumption should not vary when I touch the screen in suspended mode, but I've already debugged this issue in the past on the original Pinephone, and I was able to just enable the solution I've implemented to this problem previously. This solution is to power down the touchscreen in system suspend completely. With that the suspend power consumptions stays at 400mW no matter what I do
If "power down the touchscreen" means what it sounds like it does then I doubt it would be possible to still use gestures to send any signals to wake up the device from suspend.
double tap to wake support - by bam - 11-03-2021, 04:03 PM
RE: double tap to wake support - by ryo - 11-04-2021, 02:41 AM
RE: double tap to wake support - by marcih - 11-04-2021, 02:48 AM
RE: double tap to wake support - by bam - 11-04-2021, 05:08 AM
RE: double tap to wake support - by ryo - 11-04-2021, 06:45 AM
RE: double tap to wake support - by bam - 11-04-2021, 07:22 AM
  Looking to pay for support. profileyourcity 1 815 09-18-2023, 12:25 PM
Last Post: zetabeta
  My customer support experience ionmich 1 809 08-15-2023, 03:17 PM
Last Post: fxc
  US Mobile, via T-Mobile, won't support Pinephone Pro - SOLVED, SIMPLY jovval 10 3,492 07-07-2023, 12:06 PM
Last Post: jovval
Lightbulb Suggestion: NFC-F / FeliCa Support for next gen PinePhone or board add-on iamauser 0 781 03-11-2023, 10:21 AM
Last Post: iamauser
Sad PinePhone carrier support bucnham 2 1,217 12-27-2022, 12:37 AM
Last Post: rocket2nfinity
  pinephone-support package not upgradable on Mobian fhireman 4 2,450 09-24-2022, 08:01 AM
Last Post: dante404
  Carriers do not support PinePhone? rey70 22 13,660 02-07-2022, 09:06 PM
Last Post: bcnaz
  SD nonfunctional, how is support supposed to work? slomobile 6 4,116 01-18-2022, 07:02 PM
Last Post: slomobile
Sad Problems with PINE64 Support Astilex 1 2,502 04-05-2021, 12:48 AM
  PinePhone development questions (Or: U-Boot PinePhone 3GB support) jbit 1 2,968 09-03-2020, 01:34 AM
Last Post: jbit
