I am considering a pinephone but have a question first
(10-08-2021, 12:02 PM)flatulent_piney Wrote: I contacted my carrier to determine whether they could support the pinephone on their network.
I'd not blindly trust that.
I once sat down at the nearest by SoftBank branch store for 2 long hours, they kept asking me what Android version my PinePhone was running on, even after saying multiple times it's Linux and not Android, only to then get a confirmation from HQ that SoftBank's USIM cards only work on either Android or iOS (they're not interchangeable).
Rakuten Mobile on the other hand worked out of the box, and another forum user once confirmed they could use on NTT docomo (which is one of the big 3 here alongside SoftBank, and Rakuten Mobile uses NTT docomo's network) as well.
If it's on the Wiki and it states it works with T-Mobile, then it should work though, since this list is compiled by actual PinePhone owners who tested it first hand.
Edit:
Thanks for reminding me about the Wiki.
I just updated a little bit based on the information above.
母語は日本語ですが、英語も喋れます(ry
RE: I am considering a pinephone but have a question first - by ryo - 01-04-2022, 08:56 AM
  PinePhone - boot from microSD laserpyramid 7 619 04-25-2024, 05:56 AM
Last Post: aular
  pinephone virtual keyboard aular 4 366 04-10-2024, 03:45 PM
Last Post: aular
  PinePhone Doesn't Boot LED Doesn't Show Any Signs When Charging dorkydev 1 245 04-02-2024, 11:50 AM
  Are you using the Pinephone as your daily driver? jro 157 109,588 02-18-2024, 11:33 PM
Last Post: aular
  2020 PinePhone Manjaro CE EU for sale, name your price astrojuanlu 7 1,854 02-14-2024, 04:51 PM
Last Post: astrojuanlu
  pinephone is not bootble for the box. ijij 1 622 01-19-2024, 01:29 PM
Last Post: fxc
  Multiple issues with the Pinephone MTXP 12 2,408 12-28-2023, 07:55 AM
Last Post: MTXP
  pinephone repair shop shengchieh 0 509 12-26-2023, 02:42 PM
Last Post: shengchieh
  sudo nano file saving pinephone beta edition CharlesGnarley 4 1,728 12-22-2023, 03:44 PM
  Can't get Mobian on PinePhone to recognise USB-C docking bar duncan_bayne 9 6,998 12-04-2023, 02:14 AM
Last Post: Peter Gamma
