which distro + DE are you using these days on the Pinebook Pro?
(07-14-2021, 10:45 PM)moonwalkers Wrote: Debian Sid here. Almost stock - just extra acpid hackery for speakers muting/unmuting on headphones plugging/unplugging, WiFi/BT firmware, asound.state with immutable flag. Oh, and u-boot-rockchip from Debian Experimental. The only thing that doesn't work is deep sleep.
I installed mine completely manually, doing essentially the same thing that debootstrap does automatically, but official SD card image with u-boot from experimental should work too, though partitioning would likely need to be done manually and u-boot also needs to be installed separately from experimental.
why did you choose Debian Sid?
I'm asking because I'm after a distro and DE combo that provides the greatest performance and stability on the Pinebook Pro. (I should have pointed out in the opening post.)
(07-15-2021, 07:10 AM)jms429 Wrote: Manjaro & i3.
Find it to be pretty snappy, and the Manjaro i3 ISO has some nice defaults and everything works.
thanks. which desktop environment do you think is the best?
RE: which distro + DE are you using these days on the Pinebook Pro? - by halogen - 07-15-2021, 08:59 AM
  Boot Order in Pinebook Pro food 11 5,610 03-28-2025, 10:08 AM
Last Post: DrYak
  Upgrading Armbian from v24.2.1 gnome, breaks pinebook pro Sb2024 0 598 11-10-2024, 02:50 PM
Last Post: Sb2024
  Pinebook pro won't boot after bootloader installation jwensouls 4 2,387 08-21-2024, 04:17 AM
  [Pinebook Pro/Mobian/XFCE4] can fix touch or screen in greeter not both SynthGal 0 888 05-31-2024, 09:42 AM
Last Post: SynthGal
  Debian on Pinebook Pro u974615 7 4,783 03-31-2024, 10:11 AM
Last Post: u974615
  Pinebook Pro upgrading from the factory image yamsoup 12 7,305 02-22-2024, 04:02 PM
  Help installing Manjaro on eMMC of Pinebook Pro pine4546464 4 4,464 12-13-2023, 07:22 PM
Last Post: trillobite
  Need Help Recovering Manjaro /boot Contents on Pinebook Pro calinb 6 5,114 12-11-2023, 03:47 AM
Last Post: calinb
  Gentoo on Pinebook Pro RELEASE jannik2099 54 120,907 12-08-2023, 11:25 PM
  PineBook Pro seems to go to deep sleep, but doesn't wake up pogo 11 10,070 08-31-2023, 04:20 PM
Last Post: TRS-80
