Are you using the Pinephone as your daily driver?
#25
[*]1. Do you use the Pinephone as your daily driver?
[*]Yes, since three months ago.
[*]2. If yes: What distribution do you use?
[*]Mobian.
3. Which desktop environment/interface do you use?
[*]Phosh.
[*]4. Does the interface offer the basic functionality you need or is something missing?
[*]6. Which customisations did you apply to make the pinephone meet your expectations towards a daily driver?
[*]I keep track of the basic functionality that works for me, so that whenever I find the time I can do some tweaks and research to make thinks work.
[*]These worked out-of-the-box:
[*]- phone calls: yes
- sms: yes
- wifi: yes
- cellphone data: yes
- maps: yes
- camera: yes
- bluetooth: yes
- disk encryption: yes (during installation)
[*]- messaging apps: yes (telegram desktop)
[*]- ssh: yes (installed from the terminal)
[*]- external devices (keyboard, mouse): yes (with the usb-c dock, however the dock is not stable when plugged-in into the power for charging)
[*]These worked with some tweak:
[*]- contacts: yes (but in order to import contacts from the vcard standard, is
    necessary to go through evolution on the PC to create a database file that later
    you can copy to the phone)
- bitcoin wallet: electrum (found in the repo, but it needs manual app scaling
    APP-ID='electrum'), it is not optimized for small screens
- internet browsing: yes firefox-esr (but app scaling is needed)
[*]- hotspot: yes, but you need to add the hotspot from the terminal using `nmtui` command, let me stress that when I connect my pinephone to the laptop via the usb-c cable my laptop "sees" an ethernet connection automatically that allows me to connect to the internet without the need of the hotspot.
These are missing functionalities:
- copy/paste text: I can get the copy but not the paste, for example in SMS app.
- audio recording of phone calls: NO
- qr codes reader: NO
[*]5. Have you been able to add the missing functionality through third party applications or customisations?
[*]Never tried.
RE: Are you using the Pinephone as your daily driver? - by lagrang3 - 06-07-2021, 12:06 AM
  PinePhone - boot from microSD laserpyramid 7 630 04-25-2024, 05:56 AM
Last Post: aular
  pinephone virtual keyboard aular 4 367 04-10-2024, 03:45 PM
Last Post: aular
  PinePhone Doesn't Boot LED Doesn't Show Any Signs When Charging dorkydev 1 246 04-02-2024, 11:50 AM
  2020 PinePhone Manjaro CE EU for sale, name your price astrojuanlu 7 1,855 02-14-2024, 04:51 PM
Last Post: astrojuanlu
  pinephone is not bootble for the box. ijij 1 625 01-19-2024, 01:29 PM
Last Post: fxc
  Multiple issues with the Pinephone MTXP 12 2,411 12-28-2023, 07:55 AM
Last Post: MTXP
  pinephone repair shop shengchieh 0 511 12-26-2023, 02:42 PM
Last Post: shengchieh
  sudo nano file saving pinephone beta edition CharlesGnarley 4 1,736 12-22-2023, 03:44 PM
  Can't get Mobian on PinePhone to recognise USB-C docking bar duncan_bayne 9 7,004 12-04-2023, 02:14 AM
Last Post: Peter Gamma
  Pinephone not booting, always vibrating alexander12 7 5,025 11-22-2023, 06:46 PM
Last Post: Scary Guy
