No ability to cancel out of Applications in Both KDE Plasma AND Mobian
(02-11-2021, 08:56 AM)Basic Wrote: One pic is Manjaro KDE Plasma Mobile, the OTHER is...Mobian. The phone came with Manjaro just this month... I put Mobian on it and it has the same issues!
Swiping to exit applications does not work on Mobian for me, I just tried it every way I could, but to no effect...in any case thank you for the suggestion.  Mobian says I am Up to date....
Wifi works great on Mobian BTW, both Mobian and Manjaro read my SIM card. I wonder if it's bad /"unlucky" RAM, or some other hardware issue.
May want to give Arch a try. Arch is similar to Manjaro but more stable. I have not tried Mobian much so I can not speak to that. As for sms that should be working on both Arch, Mobian and Manjaro but obviously that can also be dependant on your carrier. I am on T-Mobile and it works great. As for swiping up on apps to close them, I know that works fine in Arch and Manjaro on Phosh by clicking the app menu arrow "^" then swiping up on whatever app you want to close at the top. Another issue I just thought of with sms is that I believe if the modem gets filled with mms messages that did not go through due to it not being implemented yet, that could block sms's from coming through. There is a way to clear them out if that happens, but I am not sure how. Maybe someone else can chime in on that part.
* Found the code to check/clear mms (See below: This was posted on Matrix and I have not tried it myself so be careful)
Shows the messages jamed up by number:
sudo mmcli -m 0 --messaging-list-sms
Then delete them one by one with this:
sudo nmcli --modem 0 --messaging-delete-sms=##
View my projects at: https://gitlab.com/users/The3DmaN/projects or at the3dman.gitlab.io you can also find me on Matrix in many of the Pine related channels.
RE: No ability to cancel out of Applications in Both KDE Plasma AND Mobian - by The3DmaN - 02-11-2021, 11:53 AM
  Can't get Mobian on PinePhone to recognise USB-C docking bar duncan_bayne 9 7,057 12-04-2023, 02:14 AM
Last Post: Peter Gamma
  Mobian PIN changed after update! Mwo87 21 17,920 12-02-2023, 11:53 PM
Last Post: Karrenbrady
  pinephone texting ability goes in an out jyoung 0 666 08-05-2023, 10:15 PM
Last Post: jyoung
  Problems updating KDE Plasma Mobile OS IMSAI8080 6 3,425 06-30-2023, 11:39 PM
Last Post: ionmich
  Cellular Data, Mobian - "No WWAN Adapter Found" justneedsomedatathanks 3 4,280 05-25-2023, 09:03 PM
Last Post: justneedsomedatathanks
  Buyer beware: Pine64 is not checking their sales email, won't alter or cancel orders 3x5co 5 4,085 01-10-2023, 06:30 PM
Last Post: 3x5co
  No sound after Mobian upgrade arbocenc 1 785 11-28-2022, 11:02 AM
Last Post: arbocenc
Exclamation No wIfI after Mobian update crakabeats 3 2,154 11-03-2022, 04:16 AM
Last Post: wifinoworkie
  pinephone-support package not upgradable on Mobian fhireman 4 2,414 09-24-2022, 08:01 AM
Last Post: dante404
  plasma-dialer doesn't call Ant 7 4,031 04-08-2022, 03:09 PM
Last Post: israel
