Batch #2 - DOA Pinecil?
While I opened a ticket to get an official answer to this issue, I'm also posting here in case there is a quick fix / known issue.
I received today my Pinecil from the 2nd batch. When plugging it to any power source (tried a few PD USB-C, and 12V DC barrel, or from the computer) the screen either stays black, or for about 1 out of 3 plugging events I'm getting a "random dots" pattern
[Image: SVb67iG.jpg]
Reading around in the forum / wiki:
- I updated the firmware to the most recent one (following http://forum.pine64.org/showthread.php?tid=12803 as the MASS_ERASE error was present for me too)
Same issue after successful update. Pinecil is detected in DFU mode as you would expect.
- I can also confirm that this device is making an annoying rattling noise http://forum.pine64.org/showthread.php?tid=12859 that seem to be coming from the DC barrel / USB-C side of the device. Opening it up did not reveal anything loose there, but confirmed the location of the noise. Not sure if normal (but slightly annoying to say the least) and unlikely to be linked to my issue as both DC barel or USB-C powering seems to result in random dots pattern.
I will update that topic when I'm hearing some news from the ticket, but hopefully someone else got the same issue and have a fix for it.
Batch #2 - DOA Pinecil? - by emc2cube - 01-23-2021, 09:50 PM
RE: Batch #2 - DOA Pinecil? - by emc2cube - 01-27-2021, 04:57 PM
RE: Batch #2 - DOA Pinecil? - by tllim - 01-27-2021, 05:23 PM
Question Can Pinecil Read USB-C Cable E-Marker Chips? Garywoo 0 32 04-23-2024, 01:48 PM
Last Post: Garywoo
  Connecting a power supply to the Pinecil jon_bondy 1 387 02-29-2024, 07:37 PM
Last Post: Okedokey
  Crippling noise from inside pinecil during a few minutes high power soldering. dreieck 2 797 01-31-2024, 12:34 AM
Last Post: suga7
Question Pinecil Tempaerature Reading jumps to Y400°C when active but stays normal when cold H3wastooshort 0 374 12-24-2023, 05:45 PM
Last Post: H3wastooshort
  Asus laptop power supply can also power Pinecil biketool 9 8,319 11-17-2023, 12:57 PM
Last Post: killingmesmalls
  Mass problem Pinecil V2 Harrysteed 0 671 11-02-2023, 09:11 AM
Last Post: Harrysteed
Question Pinecil v2 power cycles at higher voltages? clemon79 2 1,304 10-09-2023, 10:10 PM
Last Post: clemon79
  PD resets during heat up tip [Pinecil V2] Neitron4ik 2 1,557 10-09-2023, 01:22 AM
Last Post: Neitron4ik
  [Hackaday Article] All About USB-C: Pinecil Soldering Iron vajak 1 1,458 02-02-2023, 11:45 AM
Last Post: VaZso
  Brand new Pinecil v2 won't boot on PD jhutch 1 2,264 12-14-2022, 01:03 AM
Last Post: River
