Pinecil rattle?
Just received my pinecil from the 2nd production run, and something is loose inside it?
It's not just the buttons - if i hold both of them down and shake it, i can still hear something moving around inside it.
Couldn't resist. Exploratory surgery suggests that the only thing that could possibly be loose is the outer contact ring in the DC barrel, which is perfectly fine because it's a spring.
Just got mine today, it has the same rattle. Maybe this is normal since my Pinecil seems to work just fine, the rattle sound is not that noticeable to me. It should be easy to tear down and see what it is, but I don't want to ruin the grip.
Got mine today and it has a rattle to it also. Pulled it apart and it seems to be something inside the DC barrel jack or the USB port. Iron functions as expected over USB-C however. Unable to test the DC barrel jack.
  Pinepower suitable for an s23 (and a pinecil) its_lieseeeee 0 120 12-09-2024, 01:41 PM
Last Post: its_lieseeeee
  Pinecil constantly cutting out WroughtIron 0 163 11-15-2024, 10:37 AM
Last Post: WroughtIron
  Help with Pinecil saranelson 1 223 11-09-2024, 02:19 PM
  pinecil v2 reverse polarity issue adamsk1952 0 403 09-12-2024, 07:54 AM
Last Post: adamsk1952
Sad Pinecil V2 screw broken! Carol8 1 284 09-09-2024, 08:44 AM
Last Post: Carol8
  Pinecil on Amazon? WEF 5 1,878 09-05-2024, 08:23 AM
Last Post: Jeb
Question Pinecil v2 power cycles at higher voltages? clemon79 3 2,321 08-10-2024, 05:47 AM
Last Post: RevAngel
Question Can Pinecil Read USB-C Cable E-Marker Chips? Garywoo 1 769 05-13-2024, 01:31 PM
  Connecting a power supply to the Pinecil jon_bondy 1 1,076 02-29-2024, 07:37 PM
Last Post: Okedokey
  Crippling noise from inside pinecil during a few minutes high power soldering. dreieck 2 1,596 01-31-2024, 12:34 AM
Last Post: suga7
