touchpad on pinebook issues?
I don't know where to begin looking for that file on your system. But here's how you can tell if you have it. Open a terminal window. Be yourself, not root.
Type "find / | grep kcm_touchpad" without the quotes.
That's going to give you a bunch of messages saying that it can't traverse certain directories. But if you have the file, it will tell you where it is.
I've read several places where people complained that they didn't have that file in Linux, with KDE Plasma. I have NetBSD with KDE Plasma, and I don't have the file.
Your operating system is a flavour ("distru") of GNU/Linux, called KDE Neon, which is a fork of Ubuntu, which is a fork of Debian. You have a Desktop Environment, which probably runs atop X (X11). The Desktop Environment that you use is the K Desktop Environment, or KDE. Plasma is the name for the typical configuration of KDE.
You could run Debian with KDE and everything would probably look the same, but would be less confusing under the hood. The advantage of Ubuntu though is that it's popular. I'm not sure if that's an advantage on the Pinebook.
For what it's worth, I tried checking/unchecking Reverse Scroll Direction on NetBSD in KDE (and XFCE) to no avail, unfortunately.
touchpad on pinebook issues? - by ron_burgundy - 12-17-2020, 05:26 PM
RE: touchpad on pinebook issues? - by KC9UDX - 12-17-2020, 07:03 PM
RE: touchpad on pinebook issues? - by KC9UDX - 12-17-2020, 07:32 PM
RE: touchpad on pinebook issues? - by KC9UDX - 12-17-2020, 10:42 PM
RE: touchpad on pinebook issues? - by jezek - 12-18-2020, 09:32 AM
RE: touchpad on pinebook issues? - by KC9UDX - 12-18-2020, 10:20 AM
RE: touchpad on pinebook issues? - by KC9UDX - 12-18-2020, 04:57 PM
RE: touchpad on pinebook issues? - by KC9UDX - 12-18-2020, 07:49 PM
RE: touchpad on pinebook issues? - by KC9UDX - 12-19-2020, 04:43 PM
  pinebook 1080p power/barrel connector/cable cel 0 560 08-03-2023, 11:43 AM
Last Post: cel
  eMMC compatible with Pinebook leperotero 0 1,394 07-19-2022, 07:15 AM
Last Post: leperotero
Heart [solved] Anyone selling their Pinebook? feyn 0 1,250 07-11-2022, 03:38 PM
Last Post: feyn
  Move PB Pro eMMC 128 GB to Pinebook 11 1080p petet0n76 1 1,667 06-07-2022, 10:35 PM
  UART switch Pinebook 11.6" irongarment 3 3,391 01-03-2022, 03:28 AM
Last Post: kqlnut
Exclamation "6" Key direly needed for 11" Pinebook Corkonian 1 2,646 09-25-2021, 12:03 AM
  Pinebook 14 " Battery Swollen/Bulged billjon 1 3,651 01-13-2021, 11:03 AM
Last Post: barray
  Pinebook doesn't charge anymore Reinoud 0 2,697 08-20-2020, 08:18 AM
Last Post: Reinoud
Information How To Setup Serial Console Cable Over the Pinebook MarkHaysHarris777 4 22,976 07-02-2020, 06:33 PM
  How to write image to emmc module on the pinebook eclay 16 34,045 06-11-2020, 03:03 PM
Last Post: jezek
