touchpad on pinebook issues?
KDE Plasma Workspaces
enter KDE System Settings
choose Hardware / Input Devices / Touchpad (If it's not there, install kcm_touchpad first, then restart System Settings. It's installed by default.)
select the Tapping tab
check the "Enable tapping" checkbox
set some tapping actions under "Buttons" below, the default is to do nothing
So under my settings the touchpad option is there but nothing is selectable because it says no touchpad detected..it thinks the touchpad is a mouse..would the install kcm_touchpad fix this?
I guess I can give it a shot what do I do type sudo install kcm_touchpad in terminal?
well got into mouse settings and somehow i now have two finger scrolling! i clicked the invert scroll direction a couple of times and somehow it just came to life...still no pinch to zoom or tap click but the ability to scroll has made this thing much less painful to use haha
not sure what happened here, but ill take it. thanks for the help everyone
touchpad on pinebook issues? - by ron_burgundy - 12-17-2020, 05:26 PM
RE: touchpad on pinebook issues? - by KC9UDX - 12-17-2020, 07:03 PM
RE: touchpad on pinebook issues? - by KC9UDX - 12-17-2020, 07:32 PM
RE: touchpad on pinebook issues? - by KC9UDX - 12-17-2020, 10:42 PM
RE: touchpad on pinebook issues? - by jezek - 12-18-2020, 09:32 AM
RE: touchpad on pinebook issues? - by KC9UDX - 12-18-2020, 10:20 AM
RE: touchpad on pinebook issues? - by KC9UDX - 12-18-2020, 04:57 PM
RE: touchpad on pinebook issues? - by ron_burgundy - 12-18-2020, 06:27 PM
RE: touchpad on pinebook issues? - by KC9UDX - 12-18-2020, 07:49 PM
RE: touchpad on pinebook issues? - by KC9UDX - 12-19-2020, 04:43 PM
  pinebook 1080p power/barrel connector/cable cel 0 546 08-03-2023, 11:43 AM
Last Post: cel
  eMMC compatible with Pinebook leperotero 0 1,380 07-19-2022, 07:15 AM
Last Post: leperotero
Heart [solved] Anyone selling their Pinebook? feyn 0 1,232 07-11-2022, 03:38 PM
Last Post: feyn
  Move PB Pro eMMC 128 GB to Pinebook 11 1080p petet0n76 1 1,639 06-07-2022, 10:35 PM
  UART switch Pinebook 11.6" irongarment 3 3,345 01-03-2022, 03:28 AM
Last Post: kqlnut
Exclamation "6" Key direly needed for 11" Pinebook Corkonian 1 2,616 09-25-2021, 12:03 AM
  Pinebook 14 " Battery Swollen/Bulged billjon 1 3,624 01-13-2021, 11:03 AM
Last Post: barray
  Pinebook doesn't charge anymore Reinoud 0 2,681 08-20-2020, 08:18 AM
Last Post: Reinoud
Information How To Setup Serial Console Cable Over the Pinebook MarkHaysHarris777 4 22,932 07-02-2020, 06:33 PM
  How to write image to emmc module on the pinebook eclay 16 33,863 06-11-2020, 03:03 PM
Last Post: jezek
