Pinetab Mobian optimization
(11-28-2020, 12:48 PM)barray Wrote: I've found that the more disk logging you do, the worse it gets with an SD card. I'm looking forward to being able to throw an M.2 in there so the bottleneck isn't the disk.
Checkout links like this and experiment: https://stackoverflow.com/questions/1735...le-all-log
One thing you should also do is checkout `top` whilst running these things. I'm working on my own window manager and found that some window decorations real bog down the CPU, causing a lagging feeling and making the PineTab seem unresponsive.
Does your observation about disk logging also apply when running the OS from the internal eMMC?
rsyslog is not used in Mobian on the Pinetab.
$ sudo service rsyslog stop
Failed to stop rsyslog.service: Unit rsyslog.service not loaded.
Pinetab Mobian optimization - by tomoqv - 11-28-2020, 08:00 AM
RE: Pinetab Mobian optimization - by guenther - 11-28-2020, 08:58 AM
RE: Pinetab Mobian optimization - by barray - 11-28-2020, 12:48 PM
RE: Pinetab Mobian optimization - by tomoqv - 11-29-2020, 03:56 AM
RE: Pinetab Mobian optimization - by barray - 11-30-2020, 07:14 PM
RE: Pinetab Mobian optimization - by tomoqv - 12-01-2020, 05:59 AM
RE: Pinetab Mobian optimization - by barray - 12-01-2020, 03:03 PM
RE: Pinetab Mobian optimization - by guenther - 12-01-2020, 04:57 PM
RE: Pinetab Mobian optimization - by tomoqv - 12-02-2020, 03:26 AM
RE: Pinetab Mobian optimization - by neiltholland - 01-23-2021, 01:55 PM
RE: Pinetab Mobian optimization - by brorean - 02-03-2021, 07:59 PM
RE: Pinetab Mobian optimization - by barray - 02-05-2021, 12:11 PM
RE: Pinetab Mobian optimization - by brorean - 02-05-2021, 07:56 PM
RE: Pinetab Mobian optimization - by barray - 02-06-2021, 04:36 AM
  PineTab 2 login screen rotation fix chzbacon 11 4,153 03-17-2024, 04:53 PM
Last Post: mtomaschett
  NixOS on PineTab 2 asonix 3 2,113 02-24-2024, 12:29 PM
Last Post: Evergreen
  [PineTab2] Issues with Mobian Networking Cornelia Xaos 7 2,683 12-30-2023, 10:02 PM
Last Post: Cornelia Xaos
  Mobian Boot Problem rogerwegmann 14 3,871 12-13-2023, 11:04 AM
Last Post: diederik
  Working OS on pinetab RISC-V? user641 3 829 12-13-2023, 08:11 AM
  Mobian won't boot after ton of updates bartgrefte 11 4,834 12-10-2023, 02:47 AM
Last Post: bartgrefte
  Pinetab 2 as Pinebook Pro replacement Corkonian 4 2,282 08-15-2023, 11:22 AM
Last Post: CadenAnderson
  Software for PineTab-V msm 12 4,695 08-05-2023, 05:08 PM
Last Post: bingch
  Mobian - Phosh frtodd 1 1,241 06-18-2023, 04:51 AM
Last Post: GloriousCoffee
  Arch Linux ARM on PineTab 1 Danct12 25 29,843 06-10-2023, 05:33 PM
Last Post: fxc
