LCD Enclosure on a budget!
I love my pine, but I was getting fed up of having the LCD panel dangling from the acrylic enclosure. I will be purchasing the playbook case as soon as it is available but until then I decided to MacGyver one using the existing pine64 carboard box.
I used the bottom of the acrylic enclosure to give it a little bit of stability but you can do this without it. I screwed small screws into the cardboard to keep it sliding around (which is where I added the acrylic base). I cut out holes for all the ports, and then made small indentations for the LCD screen to sit in. I have used elastic bands to fix the screen.
I hope you like it, and it makes you smile, I am quite please with it! Check out the pics.
Alex
[Image: WP_20160531_20_34_14_Rich.jpg]
[Image: WP_20160531_20_34_20_Rich.jpg]
[Image: WP_20160531_20_34_28_Rich.jpg]
[Image: WP_20160531_20_34_38_Rich.jpg]
[Image: WP_20160531_20_35_03_Rich.jpg]
[Image: WP_20160531_20_35_21_Rich.jpg]
LCD Enclosure on a budget! - by ajsullivan - 05-31-2016, 01:47 PM
RE: LCD Enclosure on a budget! - by Luke - 05-31-2016, 01:53 PM
RE: LCD Enclosure on a budget! - by Ghost - 06-04-2016, 12:03 PM
Video 7" LCD wooden framen enclosure for Pine64 *UPDATED WITH killor 12 19,865 10-12-2018, 03:08 PM
Lightbulb Perfect ABS Plastic Server Enclosure from Radio Shack MarkHaysHarris777 14 34,102 09-11-2017, 11:39 AM
Last Post: stuartiannaylor
Rainbow (Cluster) Modified Playbox Enclosure Progress predominant 3 5,456 06-17-2017, 01:29 AM
Last Post: pfeerick
  Nostalgic enclosure VHS carlo318 4 7,516 03-05-2017, 04:56 PM
Last Post: carlo318
  How is the battery Supposed to be mounted in the PlayBox enclosure? dbarbee 2 5,691 02-12-2017, 10:17 PM
  Enclosure for flush-mounting the 7" touchscreen Learnincurve 9 12,960 02-07-2017, 08:45 PM
Last Post: Bluphire
  Official C4 Labs LCD Enclosure *UPDATED WITH ASSEMBLY VIDEO* Bluphire 12 24,906 01-06-2017, 03:15 AM
Last Post: Learnincurve
  Tablet Enclosure Vachtra 11 19,958 12-20-2016, 07:17 AM
Last Post: Toriless
Rainbow PineA64 Home-Brew card-board Play Box for Android & LCD Enclosure MarkHaysHarris777 9 18,986 11-01-2016, 06:23 PM
  White box plastic enclosure clawinus 3 6,603 10-13-2016, 08:47 AM
Last Post: Bluphire
