Fedora 33 Workstation Upgrade
(10-29-2020, 05:29 PM)Upokupo Wrote:
(10-29-2020, 12:35 PM)wdt Wrote: I am wondering, 2 questions
Did you get your image from https://builds.armdevelopers.com/pineboo...eases/dev/ OR by the git install?
Just exactly how did you upgrade?
I got it from the armdevelopers. After I installed 32, I researched on the Fedora sites how to perform an upgrade to 33. I have reverted back to 32 because things weren't working correctly and was having some issues. Suspend would totally freeze the system in gnome. I tried to install deepin desktop and panel kept crashing the system and locking it up. Also, there were some graphical degradations as well. I may have jumped the gun a bit on upgrading. Everything from the armdevelopers works much better.
I followed the instructions from here:
Fedora Version Upgrade
So you installed the workstation 32 (2.8GB compressed file) on the emmc or sd? And the upgraded version is very unstable? Did you have to increase the partition size somehow? I remember a previous fedora installation of mine constantly complaining about full storage although it was utilizing only 512 of my 32GB sd card.
Is there a tutorials of how to install to emmc?
And don't you find the fedora performance very slow?
Fedora 33 Workstation Upgrade - by Upokupo - 10-27-2020, 12:18 PM
RE: Fedora 33 Workstation Upgrade - by wdt - 10-29-2020, 12:35 PM
RE: Fedora 33 Workstation Upgrade - by Upokupo - 10-29-2020, 05:29 PM
RE: Fedora 33 Workstation Upgrade - by pineitup - 10-29-2020, 07:00 PM
RE: Fedora 33 Workstation Upgrade - by Upokupo - 10-29-2020, 07:10 PM
RE: Fedora 33 Workstation Upgrade - by wdt - 10-29-2020, 09:04 PM
RE: Fedora 33 Workstation Upgrade - by Upokupo - 10-30-2020, 07:53 AM
RE: Fedora 33 Workstation Upgrade - by wdt - 10-30-2020, 09:00 AM
RE: Fedora 33 Workstation Upgrade - by kendew - 11-11-2020, 03:39 PM
  Fedora 37 installation gswatkins 16 6,180 03-16-2024, 03:09 PM
Last Post: michel_luc
  Fedora 36 -> 37 upgrade kills system tydeman 0 464 10-28-2023, 09:53 AM
Last Post: tydeman
  Upgrade Fedora from 37 to 38? acruhl 2 924 07-12-2023, 09:31 PM
Last Post: acruhl
  upgrade problem trying4firstbass 1 803 11-28-2022, 01:44 AM
  Fedora Workstation (36) on Pinebook Pro u974615 13 7,387 09-02-2022, 11:24 AM
Last Post: u974615
  No audio on Pinebook Pro with Fedora? foobar 1 1,423 08-22-2022, 12:12 PM
Last Post: snorwood
  Fedora 33 to 34 upgrade issues tydeman 2 2,499 12-02-2021, 02:43 AM
Last Post: linuxfreund
  setting up fedora from minimal install pine76 0 1,340 11-30-2021, 10:47 AM
Last Post: pine76
Question Can't boot any operating system other than Fedora after following the nullr0ute guide TDC_PBP 1 2,462 10-09-2021, 07:35 PM
Last Post: TangoZuluTango
  Sound stuttering on Manjaro gnome after latest kernel upgrade? pjsf 0 1,802 07-13-2021, 10:37 PM
Last Post: pjsf
