UPDATED (June 2021): 17-distro multi-boot image for Pinephone (incl. 3GiB variant)
#33
Here's the updated image that also supports Braveheart: https://xnux.eu/p-boot-demo/
I manged to fix UT's first boot crashing. If the file userdata/.writable_image is not present, some boot script just tries to reboot the phone and crashes the boot process. Pretty random.
(09-14-2020, 06:48 AM)LinAdmin2 Wrote: I could not download by torrent because the firewall blocked it.
Now a friend did the download for me and I flashed a card with it and booted it in my phone.
Here my disillusioning experience:
ArchLinux: Prompts for login without keyboard, then crashed.
Lune OS: Requesting pwd for WiFi without keyboard, hanging there forever.
Maeom Leste: No phone calls possible.
KDE Neon: Crashing or hanging when booting.
PureOS: Prompts for login without keyboard, then crashed.
Sailfish OS: Hangs forever with boot screen.
pmOS: sxmo login: Unable to continue.
Ubuntu Touch: modem power AT command ERROR during boot.
Lune OS sometimes fails this way, but usually works fine.
Arch Linux is just a base installation with no GUI, you can access it over serial port.
sxmo login is mo/1111.
Ubuntu Touch: do you run this on braveheart?
If you have random crashes and hangs, it may be because you may have either a corrupted image or SD card is misbehaving, or the filesystem got full for whatever reason. There's just 500MiB of free space on the original image. Without resizing the partition to be larger, if you run update on any of the distros (or if it has autoupdate), you'll fill the fs, and things start crashing for all distros.
md5 of the previous uncompressed image release is: 0ee480064088c457787a19037baa6582
It's always possible to verify the SD card got written properly by: dd if=/dev/sdcarddevice bs=1M count=7500 | md5sum (only immediately after flashing, and before use/mounting - if your OS has auto-mounting, it may break this verification method too)
my website: https://xnux.eu
RE: UPDATED: 13-distro multi-boot image for Pinephone 1.2 (incl. 3GiB variant) - by megous - 09-14-2020, 09:36 AM
  PinePhone - boot from microSD laserpyramid 9 793 05-03-2024, 10:09 AM
Last Post: laserpyramid
  pinephone virtual keyboard aular 4 412 04-10-2024, 03:45 PM
Last Post: aular
  PinePhone Doesn't Boot LED Doesn't Show Any Signs When Charging dorkydev 1 274 04-02-2024, 11:50 AM
  Are you using the Pinephone as your daily driver? jro 157 110,598 02-18-2024, 11:33 PM
Last Post: aular
  2020 PinePhone Manjaro CE EU for sale, name your price astrojuanlu 7 1,908 02-14-2024, 04:51 PM
Last Post: astrojuanlu
  pinephone is not bootble for the box. ijij 1 654 01-19-2024, 01:29 PM
Last Post: fxc
  Multiple issues with the Pinephone MTXP 12 2,488 12-28-2023, 07:55 AM
Last Post: MTXP
  pinephone repair shop shengchieh 0 534 12-26-2023, 02:42 PM
Last Post: shengchieh
  sudo nano file saving pinephone beta edition CharlesGnarley 4 1,776 12-22-2023, 03:44 PM
  Can't get Mobian on PinePhone to recognise USB-C docking bar duncan_bayne 9 7,064 12-04-2023, 02:14 AM
Last Post: Peter Gamma
