128GB eMMC support
(08-31-2020, 06:52 AM)dgkPBP Wrote:
(08-31-2020, 06:44 AM)tophneal Wrote: Yes, any Pine emmc is supported in the PBP (The very first public batch actually shipped with that size. I use mine and have not have an issue with it yet.)
How are you imaging your emmc?
Interesting. I wasn't sure if it was supported or not.
I'm using a USB/emmc writer with Etcher. I flashed it twice using Manjaro ARM with KDE (Plasma); no joy.
You could try using the Manjaro SD>eMMc installer image, or try going back a month or two in the Manjaro release images and trying one of them. Anything 20.02+ should be good (though i have heard of people having issues with 20.06 images.
128GB eMMC support - by dgkPBP - 08-31-2020, 05:11 AM
RE: 128GB eMMC support - by KC9UDX - 08-31-2020, 05:22 AM
RE: 128GB eMMC support - by tophneal - 08-31-2020, 06:44 AM
RE: 128GB eMMC support - by dgkPBP - 08-31-2020, 06:52 AM
RE: 128GB eMMC support - by tophneal - 08-31-2020, 07:02 AM
RE: 128GB eMMC support - by dgkPBP - 08-31-2020, 08:18 AM
RE: 128GB eMMC support - by dgkPBP - 09-08-2020, 07:26 AM
RE: 128GB eMMC support - by KC9UDX - 09-08-2020, 07:36 AM
  256GB EMMC! sallyhaj 1 833 10-03-2023, 07:42 AM
  128GB Module not booting on 2022 Pinebook Pro batch JessicaQ 0 1,082 08-12-2022, 06:41 AM
Last Post: JessicaQ
  eMMC failed Dendrocalamus64 9 7,093 11-12-2021, 11:08 AM
Last Post: Dendrocalamus64
  Upgrade eMMC card - boot problems alpopa 0 2,307 09-16-2020, 12:31 PM
Last Post: alpopa
  Manjaro 20.06 requires multiple boots from eMMC to launch successfully on PBP Spectre 0 2,239 07-09-2020, 06:12 PM
Last Post: Spectre
  eMMC to USB adapter "very" slow at reading data talpa 3 5,290 07-08-2020, 08:55 AM
Last Post: talpa
  Internal installation of additional eMMC Besouro 7 8,581 06-06-2020, 09:33 PM
Last Post: xmixahlx
  Boot problems with new 128GB eMMC module Kareema 1 3,329 05-31-2020, 10:36 AM
Last Post: Kareema
Star Could you please add 128GB eMMC as a build option for this preorder? Dendrocalamus64 3 4,531 03-23-2020, 04:54 AM
Last Post: xmixahlx
  Emmc to MicroSD adapter won't fit in recessed slot of pbp sunjam 3 4,425 03-04-2020, 01:20 PM
Last Post: zaius
