apt-get update hanging twice (work-around included)
(08-05-2020, 01:43 PM)motox6 Wrote: Sorry, I accidentally deleted the content of my prior post, because I did not understand how the reply editor worked.
So I deleted the entire post as what was left was not helpful.  (Was there a way to go back to prior versions?)
So here is synopsis without all the nice details I had in the prior post. Sad
I was doing a fresh install of Mobian to the EMMC.
I did an apt update and apt upgrade
and it got stuck at 7% for 20 hours.  Reading elsewhere I found people running into a similar issue and identify a system control restart command related to fstrim as the problem.  I killed the systemctl restart process related to fstrim
The process continued a little bit and exited.
I did another
apt upgrade
It got to 88% and got stuck again.
I killed another systemctl restart process this time related to something else.
This time the apt upgrade continued to completion.
I re-ran
apt upgrade
and
dpkg --configure -a
just to make sure everything was okay, and everything was okay.
I think in both hang cases there was also a process related to something about dialog.
Perhaps the upgrade was asking something that did not appear on the screen?
I ran the entire process once on the phone via Kings Cross and once via SSH using a screen session.
So I tried to update and upgrade this morning and it got stuck and I rebooted the phone. I then had to run dpkg --configure -a because it was interrupted but running it it gets stuck at 'Setting up apt (2.1.8) and will do nothing else.
Do you have any ideas that could possibly help me?
RE: apt-get update hanging twice (work-around included) - by livanti21 - 08-06-2020, 11:45 AM
  wwan0 (SIM interface) doesn't work with OpenVPN nickolas 6 2,204 09-05-2023, 11:16 AM
Last Post: nickolas
  Chatty does not work after suspend mode user641 4 1,995 07-18-2023, 10:43 AM
Last Post: alaraajavamma
  how to update mobian over tor vusra 13 7,102 07-09-2023, 08:57 PM
Last Post: vusra
  Wifi doesn't work after update nickolas 2 1,281 04-14-2023, 10:07 AM
Last Post: nickolas
  PinePhone won't boot after software update jb2000 2 1,375 03-17-2023, 07:26 AM
  Most recent Mobian image or installer image known to work? DrPlamsa 13 5,124 02-26-2023, 11:47 PM
Last Post: SukiiPooru
Exclamation Impossible to login since the latest update anonymous 12 4,384 02-26-2023, 01:01 PM
Last Post: anonymous
Exclamation The latest update of eg25-manager seems to cause frequent disconnections anonymous 12 4,457 11-28-2022, 03:30 PM
Exclamation The webcam doesn't work in Firefox anonymous 0 761 11-06-2022, 01:45 PM
  Wifi issue since last update and held back updates goku499 11 5,451 09-21-2022, 02:39 PM
Last Post: Katsujinken
