Bricked phone after u-boot update
Thank you @Boern , that worked.
Next time there's a u-boot update, should I do something different than what I did before? Last time I did a regular sudo apt update, checked the upgradable packages, and then sudo apt upgrade (since there were a lot of other packages needing to be upgraded as well). Afterwards, I ran sudo u-boot-install-pinephone. Should I have upgraded u-boot through this method (or the more specific one you recommended) first, and then done the sudo apt upgrade for the rest of the packages? Would like to avoid causing this problem again, thanks!
RE: Bricked phone after u-boot update - by Boern - 08-04-2020, 11:23 PM
RE: Bricked phone after u-boot update - by DarkManiels - 08-07-2020, 11:05 AM
RE: Bricked phone after u-boot update - by Boern - 08-07-2020, 11:48 AM
  mobian installed to eMMC - how to install tow-boot grump_fiddle_reinstall 6 2,046 11-22-2023, 11:46 AM
Last Post: aLoop100o
  How to check if tow-boot is installed? jojuma 3 972 09-29-2023, 11:29 PM
  Mobian boot failed with zstd message after upgrade. Mahgue 0 648 09-01-2023, 11:29 AM
Last Post: Mahgue
  how to update mobian over tor vusra 13 7,010 07-09-2023, 08:57 PM
Last Post: vusra
  4G data on default startup / boot dcinoz 1 855 04-29-2023, 11:24 PM
Last Post: dcinoz
  Wifi doesn't work after update nickolas 2 1,260 04-14-2023, 10:07 AM
Last Post: nickolas
  PinePhone won't boot after software update jb2000 2 1,359 03-17-2023, 07:26 AM
  Boot log analyses -> GPU no regulator (mali) found freelectro 0 981 03-06-2023, 12:06 PM
Last Post: freelectro
Exclamation Impossible to login since the latest update anonymous 12 4,312 02-26-2023, 01:01 PM
Last Post: anonymous
  boot gets stuck shortly after disk decryption vortex 8 4,068 02-13-2023, 02:11 AM
Last Post: sharase
