killed my pinebook pro with my pinephone
(07-22-2020, 10:13 AM)tophneal Wrote:
(07-22-2020, 09:59 AM)jvlist Wrote: i think your right. i dont think the uboot is intact and i dont have a adapter so i will open the pinebook. and disable the emmc?(this is not cleat for me from your instruction) then boot from sd, then enable emmc en rebind it.. after rebinding can i install the emmc version again?
Your uboot was most certainly trashed if you accidentally wrote a phone image to your emmc.
There is a switch to en/disable the emmc inside the PBP. (It is identified in the image of the PBP with its bottom cover removed, on the wiki.)
To hopefully remove any confusion from my quick process detail, do this:
1. Download and write a live img to an SD.
2. If the PBP is on, shut it down, leaving the lid open. Lay the keyboard tray onto a surface. (The lid should be hanging off the edge of the surface.)  *This is an important step, as opening the lid with the bottom cover removed, is likely to flex and/or break the plastics of the PBP casing.
3. Remove the bottom panel screws, and the bottom panel. *Be careful! The edges of the panel are sharp, a pry tool is recommended. Also, be mindful that the speakers are adhered to the bottom panel, so do not pull it off quickly.
4. Locate the emmc switch and move it opposite the direction it is in (>OFF.)
5. Ensure you live SD is in the PBP SD slot, and turn on the PBP.
6. When the SD OS has started to boot, carefully flip the PBP over to return the emmc switch to its original position (<ON.) Then, carefully flip the PBP back over, so it the keyboard is up.
7. Once the SD OS has booted, open terminal and run these commands as root or sudo:
echo fe330000.sdhci >/sys/bus/platform/drivers/sdhci-arasan/unbind
8. Verify the emmc is now recognized within the SD OS. (Most live distros will have a Disk Utility available.)
9. Download (or transfer from another computer using USB) the OS img you want to write to your emmc, to the PBP.
10. Write the img to your emmc.
11. After writing the img completes, shutdown the PBP, remove the SD, and reinstall the bottom panel.
You should now be able to boot your PBP into your newly installed image, from the emmc.
RE: killed my pinebook pro with my pinephone - by Jny - 07-25-2020, 12:33 PM
Thumbs Up Finally got Kali working on my Pinebook Pro! qingss0 0 289 04-04-2026, 08:00 AM
Last Post: qingss0
  dead Pinebook - help please RicTor 3 994 03-26-2026, 04:22 PM
Last Post: williamcorlin
  Pinebook problem meghancordo 2 4,799 03-18-2026, 08:58 AM
Last Post: RicTor
  Pinebook Pro in EU for Sale - €90 jan_vdk 5 8,069 02-09-2026, 12:50 AM
Last Post: Anthona
  Pinebook Pro for sale rfm83 0 723 11-08-2025, 09:22 AM
Last Post: rfm83
  Pinebook pro bricked? michaelmoua 3 5,330 10-23-2025, 10:06 AM
Last Post: jceaser
Question Full desktop Surfing and Absolute Privacy on the pinebook? Www 1 7,299 08-02-2025, 08:55 PM
Question Printing and scanning documents with pinebook? Www 0 4,031 06-28-2025, 01:25 AM
Last Post: Www
  Use SD to install new OS over pinebook debian Rudy558 10 25,818 03-09-2025, 11:17 AM
Last Post: davisthomas
  Problem: Wi-Fi Connectivity Issues on Pinebook Pro markwood00 1 5,112 02-05-2025, 03:56 AM
Last Post: waylonwesley
