Android sources
(05-16-2016, 07:43 AM)IlyaM Wrote: when I try to install openjdk
apt-get install openjdk-7-jdk
I got a message that you have to choose from the list
  oracle-java9-installer 9b116+9b116arm-1~webupd8~1
  oracle-java8-installer 8u92+8u91arm-2~really8u91~webupd8~0
  oracle-java7-installer 7u80+7u60arm-0~webupd8~1
How to solve this problem with idk?
Weird, maybe it was installed idk. Maybe you can try these:
sudo update-alternatives --config java
sudo update-alternatives --config javac
if you see openjdk in output, select it.
Android sources - by IlyaM - 05-14-2016, 08:32 AM
RE: Android sources - by lenny.raposo-pine64.pro - 05-14-2016, 08:36 AM
RE: Android sources - by IlyaM - 05-14-2016, 08:50 AM
RE: Android sources - by IlyaM - 05-15-2016, 03:05 PM
RE: Android sources - by Hahaburger - 05-16-2016, 07:26 AM
RE: Android sources - by IlyaM - 05-16-2016, 07:43 AM
RE: Android sources - by Hahaburger - 05-16-2016, 08:17 AM
RE: Android sources - by IlyaM - 05-16-2016, 08:21 AM
RE: Android sources - by Hahaburger - 05-16-2016, 08:30 AM
RE: Android sources - by IlyaM - 05-16-2016, 08:37 AM
RE: Android sources - by Hahaburger - 05-16-2016, 09:00 AM
RE: Android sources - by IlyaM - 05-16-2016, 09:27 AM
RE: Android sources - by Hahaburger - 05-16-2016, 10:04 AM
RE: Android sources - by IlyaM - 05-16-2016, 10:20 AM
Android sources - by IlyaM - 05-23-2016, 11:42 AM
  Android 6.0 Tablet and TV (release candidate, maintained) ayufan 228 393,721 12-29-2020, 01:13 AM
Last Post: firmwarefile
Shocked Remote for Android? liodra 18 30,159 12-23-2020, 06:11 AM
Last Post: Learnincurve
  Adding an accelerometer to Android modsbyus 11 17,097 11-02-2020, 08:12 PM
Last Post: Little_Johnny
  Android Things OS dqvsra 2 7,074 12-03-2019, 09:52 AM
Last Post: hangglider
  Is there another link for Android images? Maalth 3 7,164 10-10-2019, 07:57 AM
Question Android SDK Oreo NGC6691 2 5,694 07-15-2019, 08:29 PM
Last Post: dazza5000
  Putting Android 9 RockPro64 source into easier to manage repositories dazza5000 0 3,389 07-15-2019, 08:29 PM
  Android 5.1.1 TV (old-stable, no longer maintained) ayufan 194 262,600 03-12-2019, 04:53 PM
Last Post: neosapien
  Issues with SD Card and Running Android Twistedx 0 3,596 02-26-2019, 11:58 AM
Last Post: Twistedx
  Android 7.1 (PINE A64(+)) pineadmin 59 106,821 02-10-2019, 07:44 PM
Last Post: mmmarcus
