Manjaro 20.06 Step-By-Step Installation Guide
(06-24-2020, 12:56 AM)nathanielwheeler Wrote:
(06-23-2020, 10:59 PM)evj Wrote: (quote omitted for brevity)
Thanks! I have not yet tried your directions, but everything else I tried either failed, or the result was sooooo slow in booting, I gave up. In my many attempts, I destroyed the micro holder; I will have to physically hold it in, else devise some mechanical means (shoestring?) to hold the microSD in place.
Try pressing a key like ESC in your perpetual boot,there is a bug in the arm manjaro eMMC installer where it isn't loaded until you escape from the boot splash screen.
Keep in mind, if you're using the 20.04 eMMC installer, there's another bug that crashes the installer when you attempt to select the drive to install to.
I succeeded in booting from the micro. Used dd unto the micro; could not get the right Etcher to work on PBP. Now I am ready to do the final step. Do not understand why I need to get a fresh image; the original is till there. How do I identify the destination?
'lsblk -p' gives:
NAME        MAJ:MIN RM  SIZE RO TYPE MOUNTPOINT
mmcblk1      179:0    0 58.2G  0 disk
mmcblk1p1    179:1    0  64M  0 part /boot
mmcblk1p2    179:2    0 58.1G  0 part /
mmcblk1boot0 179:32  0    4M  1 disk
mmcblk1boot1 179:64  0    4M  1 disk
mmcblk1rpmb  179:96  0  16M  0 disk
Is mmcblk1p1 or mmcblk1p2 the correct destination?
Would appreciate an answer.
RE: Manjaro 20.06 Step-By-Step Installation Guide - by evj - 06-24-2020, 07:24 PM
  PulseAudio dropouts after Manjaro Testing 2025.07.26 update Dendrocalamus64 2 2,782 08-08-2025, 02:39 PM
Last Post: Dendrocalamus64
  pbp with manjaro arm seems to not find any hardware[no wifi, blutooth or battery] frank_philip 4 4,188 03-15-2025, 01:47 AM
Last Post: frank_philip
  new manjaro install: wlan0 stuck in setting network address zkajdan 5 4,723 02-19-2025, 12:49 PM
Last Post: zkajdan
  Pinebook pro won't boot after bootloader installation jwensouls 4 6,039 08-21-2024, 04:17 AM
  Fedora 37 installation gswatkins 16 16,134 03-16-2024, 03:09 PM
Last Post: michel_luc
  Manjaro Sway Theme Broken Eighty8 1 3,218 03-08-2024, 08:41 AM
Question Manjaro with Full Disk Encryption and GRUB dumetrulo 1 5,554 02-02-2024, 02:45 AM
Last Post: frankkinney
  Manjaro network problem late 2023 acruhl 1 2,881 01-19-2024, 11:32 PM
  Help installing Manjaro on eMMC of Pinebook Pro pine4546464 4 8,063 12-13-2023, 07:22 PM
Last Post: trillobite
  Need Help Recovering Manjaro /boot Contents on Pinebook Pro calinb 6 9,148 12-11-2023, 03:47 AM
Last Post: calinb
