Running x86 software
Eight Bit; Never used Docker, have looked at it but feeling kind of confused. I'll keep looking into it.
I did try to compile the box86 on the PineBook tho, but gave errors and could not compile.
Syonyk; Okay, well, I don't mind a performance drop, but 10% might be a bit to bad..
Wizzard; Dosbox runs fine, but in this case there are a few apps I want to run which are native on Linux (Ledger Live for example).
Running x86 software - by GloriousCoffee - 06-11-2020, 08:32 AM
RE: Running x86 software - by Eight Bit - 06-11-2020, 09:25 AM
RE: Running x86 software - by feoh - 08-25-2020, 08:12 AM
RE: Running x86 software - by appelgriebsch - 08-25-2020, 09:28 AM
RE: Running x86 software - by Syonyk - 06-11-2020, 10:27 AM
RE: Running x86 software - by Wizzard - 06-11-2020, 12:26 PM
RE: Running x86 software - by GloriousCoffee - 06-12-2020, 01:25 AM
RE: Running x86 software - by Syonyk - 06-12-2020, 10:42 AM
RE: Running x86 software - by GloriousCoffee - 06-12-2020, 01:32 PM
RE: Running x86 software - by Eight Bit - 06-12-2020, 02:25 PM
RE: Running x86 software - by jiyong - 08-28-2020, 04:41 AM
RE: Running x86 software - by pcx - 02-14-2021, 07:25 PM
RE: Running x86 software - by jiyong - 02-15-2021, 11:43 AM
RE: Running x86 software - by brzegorz - 08-29-2020, 06:23 AM
RE: Running x86 software - by icecream95 - 08-30-2020, 04:16 AM
RE: Running x86 software - by hthiemann - 08-29-2020, 06:43 AM
RE: Running x86 software - by brzegorz - 08-29-2020, 07:20 AM
RE: Running x86 software - by slyecho - 08-30-2020, 06:46 AM
RE: Running x86 software - by brzegorz - 10-01-2020, 11:31 AM
  Error trying to update Manjaro software boosterh 5 2,973 08-31-2022, 10:28 PM
Last Post: shulamy
  Is anyone successfully running guix system on PBP bluekeys 8 8,126 08-29-2022, 01:19 PM
Last Post: bluekeys
  Manjaro and Arch repository with privacy oriented software as400 86 115,817 04-27-2022, 07:44 AM
Last Post: annahellrothsparent
  software request: LuckyBackup mexsudo 2 2,137 11-25-2021, 05:59 AM
Last Post: mexsudo
  Where to find a PDF viewer (and other software) compatible with aarch64? mjc 8 9,038 09-29-2020, 07:55 AM
Last Post: hmuller
  Error when running pinebook-pro-keyboard-updater NoahB 13 15,351 07-29-2020, 06:33 PM
Last Post: guiltydoggy
  Software Compatibility, If on Pi then? chetchinglo 5 6,873 06-06-2020, 07:11 PM
Last Post: chetchinglo
  Arm supported software nabeel 1 2,611 03-18-2020, 08:47 AM
  Running into problems while installing RStudio from sources FingO 0 1,771 02-01-2020, 07:05 AM
Last Post: FingO
