software request: LuckyBackup
good morning.
I would like to use LuckBackup on my PBP.
Maybe I am just dim, but searching with the "add/remove software" gizmo I only find other rsync front-ends.
Do I need to enable other repositories? If so, please tell me how.
Thanks, Peter
if you're using Manjaro, within the Add/Remove Software app (pamac) go tot he preferences and enable the AUR. Search for LuckyBackup. Just looked at it's pkgbuild to verify and it should have no problem installing on aarch64.
thanks! I did not look in preferences before
got it going
  Error trying to update Manjaro software boosterh 5 9,318 08-31-2022, 10:28 PM
Last Post: shulamy
  Manjaro and Arch repository with privacy oriented software as400 86 217,760 04-27-2022, 07:44 AM
Last Post: annahellrothsparent
  Running x86 software GloriousCoffee 19 40,069 02-15-2021, 11:43 AM
Last Post: jiyong
  Where to find a PDF viewer (and other software) compatible with aarch64? mjc 8 16,845 09-29-2020, 07:55 AM
Last Post: hmuller
  Software Compatibility, If on Pi then? chetchinglo 5 11,400 06-06-2020, 07:11 PM
Last Post: chetchinglo
  Arm supported software nabeel 1 4,803 03-18-2020, 08:47 AM
