Where to find a PDF viewer (and other software) compatible with aarch64?
I just tried and failed to install foxitreader. Is there anything available?
Also, I get the impression I'm going to have to post on the forum like this for most pieces of software. I was pleased to find https://privacyshark.zero-credibility.net/# earlier as a source of compatible VOIP software. Are there similar places to go for other aarch64 Linux software?
On Manjaro? I use xpdf for most things, evince if I need fillable forms. "pacman -Ss pdf viewer" shows several other options. Okular is preinstalled on KDE.
What distro & desktop environment are you on? If Manjaro/KDE, click the M at the bottom left of the screen, then Applications > Settings > Add/Remove Software. Hit the magnifying glass, type pdf.
(09-18-2020, 08:09 PM)Dendrocalamus64 Wrote: On Manjaro?  I use xpdf for most things, evince if I need fillable forms.  "pacman -Ss pdf viewer" shows several other options.  Okular is preinstalled on KDE.
Evince seems usable, though much sparser than Foxit.
I'm on Manjaro, but more often than not when I try to install things on pamac I get "==> ERROR: [software] is not available for the 'aarch64' architecture."
Blame the software vendor because they hadn't ported it
From Foxit site:
Foxit PhantomPDF (Prior to version 10.1)/Foxit Reader (Prior to version 10.0) is not compatible with computers with Arm processor.
and Foxit Reader itself for linux has been discontinued
https://forums.foxitsoftware.com/forum/p...post179663
Install Synaptic and you can search and browse packages yourself. I've used xpdf for 20 years or so. I haven't found much missing from aarch64 that's on other things. Some day I'll try to resurrect Photoprint again.
We're on Manjaro now, though. Synaptic is on Debian and derived distros; Manjaro has pamac, which OP is already using, octopi, and other GUI software managers. The Manjaro wiki has a page on them but it's currently down.
While several arm flavors are release architectures on debian, which means substantially all packages must build for them, arm support in arch & manjaro is still experimental. So even though manjaro's support for PBP is better in some ways, there are noticeably more packages not available for arm.
I'm not sure why no one has mentioned qpdf/qpdfview
Not my favorite, but generally OK
I don't know if it can successfully fill out forms
(09-27-2020, 08:43 AM)wdt Wrote: I'm not sure why no one has mentioned qpdf/qpdfview
Tabs is one of the main features I want, and qpdf installed without a problem, so this is the best suggestion so far. Thanks.
zathura hasn't been mentioned, it has a tabs feature although I don't use it. It's what I settled on over the years.
  pbp with manjaro arm seems to not find any hardware[no wifi, blutooth or battery] frank_philip 4 6,256 03-15-2025, 01:47 AM
Last Post: frank_philip
  slarm64 (unofficial slackware) Pinebook Pro RK3399 (aarch64) mara 41 71,743 03-18-2023, 04:39 AM
  Error trying to update Manjaro software boosterh 5 9,252 08-31-2022, 10:28 PM
Last Post: shulamy
  Manjaro and Arch repository with privacy oriented software as400 86 216,748 04-27-2022, 07:44 AM
Last Post: annahellrothsparent
  software request: LuckyBackup mexsudo 2 5,767 11-25-2021, 05:59 AM
Last Post: mexsudo
  Running x86 software GloriousCoffee 19 39,964 02-15-2021, 11:43 AM
Last Post: jiyong
  Network settings, where to find the config files? hvdkooij 1 5,669 11-20-2020, 02:47 PM
Last Post: xyzzy
  Signal Desktop Builds for Manjaro aarch64 ninefathom 25 50,828 10-23-2020, 02:19 PM
Last Post: llsf
  Is there a VOIP client compatible with aarch64? mjc 4 8,864 09-18-2020, 04:03 PM
Last Post: mjc
  Remote-viewer "Bus Error" wingmanjd 6 12,943 06-09-2020, 07:29 AM
Last Post: wingmanjd
