Software Compatibility, If on Pi then?
One of the problems that ARM has, that also early x64 had, was multi-library. Meaning when x64 came out, old x86 software would not run if you booted a 64 bit OS. They solved it by having both 32 bit, (x86), and 64 bit, (x64), libraries and support. So you could run any Linux compatible x86 or x64 program, as long as you had all the dependencies.
At present, there does not seem to be this multi-library configuration for ARM, yet. The original Raspberry Pi's were 32 bit ARM. Newer ones support 64 bit ARM. So it's a toss up if the program(s) you want, will work. The original OS for the Pinebook Pros was 32 bit Debian. Now we are shipped with 64 bit Manjaro.
To be fair, most user type ARM computers are tablets, phones or single board computers. You use what they supported, (32 bit or 64 bit). It's only recently that Linux ARM laptops and some more powerful SBCs have make this desirable. (Chromebooks have an embedded OS, so again multi-library did not mater.)
This ARM multi-library feature is on my wish list.
Arwen Evenstar
Princess of Rivendale
RE: Software Compatibility, If on Pi then? - by Arwen - 06-05-2020, 04:43 PM
  Error trying to update Manjaro software boosterh 5 2,919 08-31-2022, 10:28 PM
Last Post: shulamy
  Manjaro and Arch repository with privacy oriented software as400 86 115,050 04-27-2022, 07:44 AM
Last Post: annahellrothsparent
  software request: LuckyBackup mexsudo 2 2,113 11-25-2021, 05:59 AM
Last Post: mexsudo
  Running x86 software GloriousCoffee 19 24,111 02-15-2021, 11:43 AM
Last Post: jiyong
  Where to find a PDF viewer (and other software) compatible with aarch64? mjc 8 8,974 09-29-2020, 07:55 AM
Last Post: hmuller
  Package compatibility fcs 6 7,919 04-10-2020, 01:49 PM
Last Post: rempfer
  Arm supported software nabeel 1 2,576 03-18-2020, 08:47 AM
