Manjaro not booting
(06-03-2020, 11:47 PM)pfeerick Wrote: If it doesn't boot from a valid MicroSD image, you unfortunately would have to remove the bottom cover, so you can flick the eMMC disable switch (#24) into the disable position, power it on with a bootable microSD image, and then 1-2 seconds after powering it on, enabling it again so that the eMMC device will be visible to the booted image.
The microSD doesn't even fit correctly in the slot.  Also I did try that but the laptop couldn't turn on with it disabled.
Manjaro not booting - by sinistermrcream - 06-01-2020, 07:13 AM
RE: Manjaro not booting - by sinistermrcream - 06-01-2020, 01:26 PM
RE: Manjaro not booting - by 7tubb9 - 06-02-2020, 03:35 PM
RE: Manjaro not booting - by pfeerick - 06-03-2020, 04:38 AM
RE: Manjaro not booting - by 7tubb9 - 06-03-2020, 07:59 AM
RE: Manjaro not booting - by p3pp3r - 06-19-2020, 11:09 PM
RE: Manjaro not booting - by pfeerick - 06-03-2020, 11:47 PM
RE: Manjaro not booting - by 7tubb9 - 06-04-2020, 10:25 AM
RE: Manjaro not booting - by tophneal - 06-04-2020, 10:33 AM
RE: Manjaro not booting - by 7tubb9 - 06-04-2020, 11:12 AM
RE: Manjaro not booting - by tophneal - 06-04-2020, 11:19 AM
RE: Manjaro not booting - by 7tubb9 - 06-04-2020, 11:57 AM
RE: Manjaro not booting - by tophneal - 06-04-2020, 12:01 PM
RE: Manjaro not booting - by 7tubb9 - 06-04-2020, 12:09 PM
RE: Manjaro not booting - by tophneal - 06-04-2020, 12:32 PM
RE: Manjaro not booting - by 7tubb9 - 06-04-2020, 12:51 PM
RE: Manjaro not booting - by tophneal - 06-04-2020, 12:53 PM
RE: Manjaro not booting - by 7tubb9 - 06-04-2020, 12:54 PM
RE: Manjaro not booting - by tophneal - 06-04-2020, 12:57 PM
RE: Manjaro not booting - by 7tubb9 - 06-04-2020, 01:43 PM
RE: Manjaro not booting - by tophneal - 06-04-2020, 01:48 PM
RE: Manjaro not booting - by 7tubb9 - 06-04-2020, 02:03 PM
RE: Manjaro not booting - by tophneal - 06-04-2020, 02:13 PM
RE: Manjaro not booting - by 7tubb9 - 06-04-2020, 02:24 PM
RE: Manjaro not booting - by tophneal - 06-04-2020, 02:28 PM
RE: Manjaro not booting - by 7tubb9 - 06-04-2020, 02:38 PM
RE: Manjaro not booting - by wdt - 06-04-2020, 06:47 PM
RE: Manjaro not booting - by Arwen - 06-04-2020, 07:16 PM
RE: Manjaro not booting - by pfeerick - 06-04-2020, 09:01 PM
RE: Manjaro not booting - by poVoq - 06-05-2020, 08:13 AM
  Manjaro versions bad and good gilwood 0 256 02-12-2024, 05:03 PM
Last Post: gilwood
  Brand new Pinebook Pro doesn't boot after Manjaro update johnboiles 8 2,245 12-15-2023, 02:11 PM
  PBP won't boot after trying to reinstall Manjaro ARM soupgirl 3 707 12-13-2023, 08:17 PM
Last Post: trillobite
  Followed the blog post to install Fedora: PBP not booting anymore koenigs 6 1,893 06-01-2023, 10:58 AM
  Games compilation howto on the Pinebook-pro (Manjaro Linux and Debian native) astr0baby 201 319,769 05-12-2023, 06:09 AM
Last Post: korreckj328
  Manjaro Plasma blinking cursor jcun4128 4 1,478 05-08-2023, 11:17 AM
  I'm booting from NVME but I want to switch back to eMMC acruhl 4 1,500 04-23-2023, 06:58 AM
Last Post: acruhl
  PBP blank screen after updating Manjaro Franko 6 2,024 04-01-2023, 07:55 AM
Last Post: hacknix
  Manjaro - which libdrm? hacknix 0 573 04-01-2023, 03:21 AM
Last Post: hacknix
  Partial boot after installing Manjaro on emmc regivanx 11 3,200 02-06-2023, 09:11 AM
