Cannot boot from SD on Convergence 3 GB model
(01-20-2022, 11:38 AM)slomobile Wrote: The recent thread you refer to is mine.  The issue is still unresolved but we did notice that any SD card inserted in the slot tends to be slightly askew and support has asked me to send an image of the physical slot.  Perhaps you can do the same.  https://ibb.co/gZ7vGMx
Your problem is you have your SDcard in the SIM slot :-)
You need to put a SIM in that slot, and the SDcard above it (closer to the back cover).
To OP - have you tried a different SDcard? If lsblk from KDE is seeing it OK you shouldn't have a (significant) h/w problem. The "old" 3Gb issue is long gone - any recent image should be fine.
RE: Cannot boot from SD on Convergence 3 GB model - by dukla2000 - 01-20-2022, 12:04 PM
  Pinephone boot. Richy_T 8 8,834 10-21-2025, 12:12 PM
Last Post: Richy_T
  How boot Alpine Linux realroot 4 5,302 11-02-2024, 01:00 PM
Last Post: linmob
  Tow boot MTXP 5 7,526 08-22-2024, 03:11 AM
Last Post: Pavlos1
  Pinephone won't boot. spha 13 17,084 05-15-2024, 10:31 PM
Last Post: Richy_T
  PinePhone - boot from microSD laserpyramid 9 10,288 05-03-2024, 10:09 AM
Last Post: laserpyramid
  PinePhone Doesn't Boot LED Doesn't Show Any Signs When Charging dorkydev 1 3,139 04-02-2024, 11:50 AM
  new pinephone regular model with nano-sim slot zetabeta 0 2,089 09-24-2023, 12:25 AM
Last Post: zetabeta
  Boot screen stuck at 'K' because of firmware deleted. poundantisec 9 14,075 08-28-2023, 11:38 AM
Last Post: fxc
  New Pinephone is dead. eMMC, boot, hardware issues. Shane 4 6,702 05-10-2023, 03:31 AM
Last Post: fxc
  UPDATED (June 2021): 17-distro multi-boot image for Pinephone (incl. 3GiB variant) megous 182 403,190 03-05-2023, 11:04 AM
Last Post: Eugo
