An unofficial Debian Installer for Pinebook Pro
(02-06-2020, 02:38 AM)danielt Wrote: I saw some of the comments about broken graphics.
I haven't seen these before so I fired up a fresh install on an SD card and that worked just fine.
However when I rebooted back into my daily driver and the display manager (gdm) wouldn't start. Once it had crashed enough times for systemd to give up restarting it I was able to get over to a console and run an apt upgrade. The package list didn't look very promising (well... a new libreoffice is nice but I didn't expect that to fix anything). However after a reboot all seems to be well again.
Does the problem reproduce reliably. In other words does anyone think the upgrade has fixed it or do you think  I spot it again in a couple of days time?
I'll keep an eye out. I'm running 3 (yes) installs of Bullseye for PBP. We do have a problem of reproducibility with anything but default installations, with the same tasksel options - but I'm not teaching Experimental Design, so we can get close!
Lately I've seen the problem recently reported by others, where the initrd will time-out looking for the encrypted RootFS, which can be corrected by manually opening luks in the busybox shell and starting /init.
More troubling, without changes I'm aware of making, initrd will timeout looking for the luks encrypted volume on nvme0n1 by UUID, not partlabel! I don't know if I care to deeply troubleshoot something like this, when the transient behavior will likely change upstream with Bullseye rolling changes. For now, I manually boot from busybox when it happens, and superstitiously re-roll my initrd update after checking fstab and crypttab when I get back to userland.
— Jeremiah Cornelius
(02-05-2020, 02:37 PM)Jeremiah Cornelius Wrote:
(02-04-2020, 03:29 PM)wasgurd Wrote:
(02-04-2020, 03:22 PM)Jeremiah Cornelius Wrote: A bunch of mesa/gl packages updated in Bullseye today, and everything is back to "normal".
There's a crash when you push Fn + F1, F2.... F12
I can't repro this.
I'm on Sid with mesa from experimental, not seeing any crashes. Though for now OpenGL compositing in KWin is unusable, have to fall back to XRender.
What's up with gparted?
It never renders right, eventually crashing the graphical session - X11 and Wayland.
Works fine for me on KDE Plasma:
[Image: attachment.php?aid=1622]
About mesa updates, etc. - if you install packages from experimental AFAIK you'd need to pin experimental archive to priority 100 to ensure APT will be installing updates from it, as by default its priority is set to 1 and will install packages from there only when explicitly asked. In my case I didn't get any mesa updates (that were upgraded in experimental from 20.0-git to 20.0-rc1) until I pinned experimental to 100. If you don't know what APT pinning is read `man apt_preferences`.
.png   Screenshot_20200206_064219.png (Size: 94.66 KB / Downloads: 734)
(02-06-2020, 08:44 AM)moonwalkers Wrote: Works fine for me on KDE Plasma:
Are you using zram? I think that this is also an issue. gparted seems to dislike these block devices it creates in RAM. May be a separate issue, tho'.
i solved difficulties with crypt by using /dev/mapper/$ in fstab in my patched installer for a separate /home. might work for you here, too.
(02-06-2020, 12:06 PM)xmixahlx Wrote: i solved difficulties with crypt by using /dev/mapper/$ in fstab in my patched installer for a separate /home. might work for you here, too.
Does this mean 2 luks encrypted disks? How is passphrase handling done at boot?
correct. same password. enter once. works perfectly.
$ sudo zramctl
NAME       ALGORITHM DISKSIZE   DATA COMPR  TOTAL STREAMS MOUNTPOINT
/dev/zram0 lzo-rle       7.6G 346.6M 94.6M 100.8M       6 [SWAP]
$ free -h
             total        used        free      shared  buff/cache   available
Mem:          3.8Gi       1.7Gi       431Mi       325Mi       1.7Gi       1.7Gi
Swap:         7.5Gi       347Mi       7.2Gi
Not sure if you're referring to the issues with X failures at startup or perhaps something else like hardware acceleration.
As far as the X startup issues go, it seems I can reliably reproduce them with clean installs from sha aa7b393.  It appears to only appear when certain desktops are selected in tasksel.  Gnome runs fine.  LXDE, XFCE, Cinnamon and Mate all induce X crashes.
Interestingly, KDE Plasma and LXQT don't crash, but don't start up either: instead we see a black screen with a movable mouse cursor.
In all crashing X cases, the log reports a seg fault with OsLookupColor+0x188 as the only stack frame, with the message
"unw_get_proc_info failed: no unwind info found [-10]".
This trace is absent from the KDE Plasma and LXQT cases, which instead mention an error line reading
"Failed to open authorization file "/var/run/sddm/{<some-guid>}": No such file or directory"
..where <some-guid> is an actual guid, though the curly braces appear literally.
I can't repro this.
your description of apt pinning is exactly correct.
experimental is default 1 priority out of 1000
installed packages are 100
default release is 500
conveniently, a combination  -1 and 1001 will purge packages and reinstate release if you have i.e. cherry picked from experimental and regret that decision, etc.
I pin experimental to 2 just to KNOW that all my configs work in policy.
unless you are on unstable it is usually a bad idea to pull from experimental, although some folks have a different take on risk and happiness than I do.
in almost every "risk" case it is cleaner and more functional to install to /usr/local from packages or upstream/git.
(02-07-2020, 01:42 AM)phs Wrote: Interestingly, KDE Plasma and LXQT don't crash, but don't start up either: instead we see a black screen with a movable mouse cursor.
The "failed to open authorization file" message is a red herring, the real problem is that sddm-greeter crashes on default Debian installation because of crash in rockchip_dri.so. Either building Mesa from git or installing the Mesa packages from experimental (where they currently have 20.0-rc1, IIRC) fixes sddm-greeter crash. Alternatively, you can add 'QT_XCB_FORCE_SOFTWARE_OPENGL=1' line to your /etc/environment, that also prevents sddm-greeter crash.
(02-07-2020, 02:02 AM)xmixahlx Wrote: conveniently, a combination  -1 and 1001 will purge packages and reinstate release if you have i.e. cherry picked from experimental and regret that decision, etc.
Just to clarify - priority of -1 means the package(s) will be completely ignored by APT, and priority 1001 and higher will happily downgrade the package(s), whereas with priority of 1000 and below only upgrades will be considered.
  Debian on Pinebook Pro u974615 7 1,289 03-31-2024, 10:11 AM
Last Post: u974615
  Pinebook Pro upgrading from the factory image yamsoup 12 1,812 02-22-2024, 04:02 PM
  Help installing Manjaro on eMMC of Pinebook Pro pine4546464 4 2,230 12-13-2023, 07:22 PM
Last Post: trillobite
  Need Help Recovering Manjaro /boot Contents on Pinebook Pro calinb 6 2,322 12-11-2023, 03:47 AM
Last Post: calinb
  Gentoo on Pinebook Pro RELEASE jannik2099 54 89,831 12-08-2023, 11:25 PM
  Boot Order in Pinebook Pro food 8 1,328 11-23-2023, 07:37 AM
  install debian on pbp jsch 7 4,144 11-22-2023, 04:22 PM
Last Post: TRS-80
  How to mainline kernel on daniel thompson's debian installer? hellojack 14 7,619 09-07-2023, 09:38 PM
  PineBook Pro seems to go to deep sleep, but doesn't wake up pogo 11 5,472 08-31-2023, 04:20 PM
Last Post: TRS-80
  Would a Pinebook Pro be good for a Linux newbie? cassado10 6 1,546 08-08-2023, 04:58 AM
Last Post: moobythegoldensock
