12-03-2019, 06:40 AM
U-Boot with direct NVMe boot support for eMMC/SPI Flash
I tried it but this is the output:
dd: writing to '/dev/mtd0': No space left on device 8129+0 records in 8128+0 records out 4161536 bytes (4.2 MB, 4.0 MiB) copied, 12.889 s, 323 kB/s I see in lsblk there is no mtd0 device, just this: mtdblock0 31:0 0 4M 0 disk mtdblock1 31:1 0 32K 0 disk mtdblock2 31:2 0 256K 0 disk So I am a little afraid to reboot now I tried to PM, but you have the PMs disabled, so I think I can reply here: pcm720 Wrote:SPI flash is not supposed to show up in lsblk because it's not a block device. Thanks, but it seems it is late for me, I rebooted already and PBP does not start now. I used Ubuntu Mate distro. I just tried cat /dev/mtd0 and the result was empty. I also found some 16 MB device in lsblk, but as you said, it should not be SPI flash. I know, it is just my fault, so I will try something with the SD cards now. I made those steps to clean those booting code from SD card but still does not boot. I guess I cannot just replace the SPi flash because it is a part of PCB, right?
12-03-2019, 02:29 PM
It is possible, but you have to unsolder the NOR flash.
I did this in the past on a board to change a sound codec. You then have to solder a new NOR flash if you want to try to flash u-boot again on it. To unsolder such chip, the best is to use a knife first to cut the feets, then remove them with the iron. Use a lot of flux and copper braid. You should train yourself to solder and unsolder SMD on old broken electronics.
12-03-2019, 02:59 PM
Just a thought :
The 'legs' look fairly long in the wiki pictures. Would it be possible to cut the legs close to the chip itself ? and solder your new chip to the existing 'legs' ? ? MAY be ugly, but a bit easier..? AS I said, Just a Thought or Question.
LINUX = CHOICES
**BCnAZ** Donate to $upport your favorite OS Team
12-03-2019, 03:08 PM
FWIW
http://opensource.rock-chips.com/wiki_Rockusb Maskrom mode If there is no bootable firmware found on board, the SoC will run Rockusb driver automatically, we call it Bootrom mode or Maskrom mode. If firmware is at somewhere of the board, in order to get into this mode, we can do something to prevent cpu read the firmware successful: for SD-card, unplug the SD-card; for eMMC, short the eMMC clock to GND; for NAND, short the data line or clock line; for SPI, short the spi signal to GND; By "reboot bootrom" command in U-Boot and Kernel, WIP. erase bootable region with non-bootable data in eMMC or other media devices ayufan has some descrition for rock64 https://github.com/ayufan-rock64/linux-b...ash-spi.md should be (almost ?) same with pinebookpro not tested and not wrapped my mind around this currently reading/following/whatever the whole thread anyway of this u-boot supports boot script, so it's possible to check for a bootable device/partition/network I don't know if u-boot can use/supports a watchdog as barebox does It's a nice feature You should check the partition size first
I solved that by flashing SPI directly from rkdeveloptool, thank to @pcm720 .
It boots after I cleaned all the boot code from my eMMC, so will try my SD cards later. (12-03-2019, 12:05 PM)Wizzard Wrote: I tried it but this is the output: @Wizzard was able to fix incomplete SPI flash using Rockchip's rkdeveloptool. Since the first 4 Mbytes of SPI image contain only DDR initialization and SPI bootcode, device got stuck in Loader mode. Connecting it with USB-C cable to PC and executing the following was enough to fix it: Code: rkdeveloptool wl 0 /path/to/spiflash.bin
I am not sure if it is related, but I am seeing the errors like this when booting and in dmesg since yesterday:
Code: rockchip-dmc dmc: Get wrong frequency, Request 800000000, Current 856000000 (12-04-2019, 12:28 PM)Wizzard Wrote: I am not sure if it is related, but I am seeing the errors like this when booting and in dmesg since yesterday: rockchip-dmc is Dynamic Memory Controller driver that dynamically adjusts DRAM frequency: http://archive.lwn.net:8080/devicetree/2...ora.com/t/ There are probably some incompatibilities between the current Trusted Firmware and kernel your distro is using: it's pretty clear that rockchip-dmc can't set the frequency it wants. I guess you can try building your own SPI image with different ATF binary (e.g. the one used in stock U-Boot) and see if that fixes these errors. |
Users browsing this thread: 8 Guest(s)
