Debian Desktop off SD?
Has anyone had any success or failure running this build off an SD card?
https://wiki.pine64.org/index.php/Pinebo...an_Desktop
I get a login, then the screen goes black, and stays that way.  Any ideas?
Yes, I flashed it yesterday to sd card and running it without problem.
Odoslané z ONEPLUS A5010 pomocou Tapatalku
I attempted to boot mrfixit's Debian desktop from SD last night 3 times and was unsuccessful. It hung every time in early boot process. It made it to boot splash but did not make it to login. Am on trip, so unable to hook up serial cable and observe what is happening. Will take a look tomorrow.
I did successfully boot ayufan's bionic lxde image off SD the first time, using the exact same process and same hardware:
  • Used PBP for this process, factory installed Debian desktop
  • Downloaded image to USB 3.0 hard drive
  • Inserted SD card
  • Verified image md5sum signature
  • Burned image to SD using dd with bs=4M conv=fsync
  • Rebooted PBP
(11-02-2019, 02:39 AM)Wizzard Wrote: Yes, I flashed it yesterday to sd card and running it without problem.
You installed a different OS.  So perhaps it is a software/firmware problem with the stock build.
Is there any other Debian than stock Debian image for PBP?
(11-03-2019, 08:34 AM)Wizzard Wrote: Is there any other Debian than stock Debian image for PBP?
I'm trying to boot the same one, except off SD.
I just tried the Bionic-LXDE image on the same card, and it worked.
(11-03-2019, 11:24 AM)zaius Wrote: I'm trying to boot the same one, except off SD.
It is very strange. Which command have you used to create bootable SD for Debian?
I just used the Pine64 installer to flash the SD.
According to someone on Discord, he needed to "edit the extlinux.conf to correct the partition UUID's" to get it to work.
Maybe you should just try dd method like when installing Ubuntu. I used this way and booted Debian without problem.
I've also tried the pinebookpro-debian-desktop-mrfixit-190905.img multiple times on 3 different microsd cards with the same results as you... I see the boot splash, briefly see the console login, and then I get a blank screen.
I've used both Etcher and dd with the same results.
Matthew
  Official Debian support moonwalkers 63 52,741 05-16-2024, 11:00 PM
Last Post: rempfer
  Debian on Pinebook Pro u974615 7 1,436 03-31-2024, 10:11 AM
Last Post: u974615
  install debian on pbp jsch 7 4,204 11-22-2023, 04:22 PM
Last Post: TRS-80
  How to mainline kernel on daniel thompson's debian installer? hellojack 14 7,713 09-07-2023, 09:38 PM
  Unable to install Debian Bullseye because of missing wifi firmware Pino64 7 4,216 07-15-2023, 02:58 PM
Last Post: u974615
Rainbow How to prevent the screen from dimming (no X/wm/desktop)? cowsay 0 568 02-16-2023, 10:58 AM
Last Post: cowsay
Question Debian (Vanilla) no output on display after Kernel update (6.0.8-1) as365n4 1 1,318 12-09-2022, 12:43 PM
Last Post: as365n4
  Unsuccessful using danielt's unofficial Debian installer on the PBP joeDoe 2 2,397 12-09-2022, 05:04 AM
Last Post: ndp
  How can I install Debian? ImmyChan 1 2,112 10-19-2022, 03:09 AM
Last Post: alpopa
  when i close my laptop lid the screen doesn't turn on? (debian bullseye based) computerc 3 1,974 09-23-2022, 08:37 PM
Last Post: computerc
