08-25-2017, 11:58 PM
Ok,Thank you!
Kernel Panic on Rock64 linux
Ok,Thank you!
08-26-2017, 06:07 PM
I also get kernel panics on every distribution I tried (and I tried nearly all), I tried two different SD cards (only have two). I could get to run an Android build though. I checked for solder bridges but I coudn't find any. Anything else I can try? (I have the 4gb model)
08-29-2017, 08:34 AM
Try different SD card, it is likely that your SD is just broken.
Homepage: https://ayufan.eu
Releases: Rock/Pro 64/Pinebook Pro: Linux; Chromium OS So/Pine A64/Pinebook: Linux; Android 6.0; Android 7.1 Buy me a Beer
09-01-2017, 07:45 AM
getting the same error. Rock64 4gig version. Multiple memory cards, multiple build OSes
09-03-2017, 06:01 PM
09-09-2017, 04:48 PM
(This post was last modified: 09-10-2017, 10:25 AM by rmbusy.
Edit Reason: Update info.
I saw a kernel panic w/ xenial-minimal-rock64-0.4.17-85-arm64.img after I unplugged a USB 3.0 hard disk (nothing was mounted on it). Seems like the OS thought it was still connected.
[ 7800.498794] INFO: task parted:5470 blocked for more than 120 seconds. [ 7800.499779] Not tainted 4.4.70-rockchip-ayufan-85 #1 [ 7800.500569] "echo 0 > /proc/sys/kernel/hung_task_timeout_secs" disables this message. [ 7800.502124] Kernel panic - not syncing: hung_task: blocked tasks [ 7800.502998] CPU: 3 PID: 29 Comm: khungtaskd Not tainted 4.4.70-rockchip-ayufan-85 #1 [ 7800.504105] Hardware name: PINE64 ROCK64 (DT) Playing with jessie-minimal-rock64-0.5.7-101-arm64.img now, and don't see the same issue. It does take several seconds for it to decide the USB device is no longer available when I unplugged the cable. Nothing was active when the cable was unplugged, it just spewed the following to the console : [ 873.393783] usb usb5-port1: Cannot enable. Maybe the USB cable is bad? [ 873.394805] xhci-hcd xhci-hcd.8.auto: Cannot set link state. [ 873.395754] usb usb5-port1: cannot disable (err = -32) [ 875.910788] usb usb5-port1: Cannot enable. Maybe the USB cable is bad? [ 875.911801] xhci-hcd xhci-hcd.8.auto: Cannot set link state. [ 875.912735] usb usb5-port1: cannot disable (err = -32) [ 878.426774] usb usb5-port1: Cannot enable. Maybe the USB cable is bad? [ 878.427787] xhci-hcd xhci-hcd.8.auto: Cannot set link state. [ 878.428729] usb usb5-port1: cannot disable (err = -32) [ 880.943791] usb usb5-port1: Cannot enable. Maybe the USB cable is bad? [ 880.944809] xhci-hcd xhci-hcd.8.auto: Cannot set link state. [ 880.945741] usb usb5-port1: cannot disable (err = -32) [ 880.946543] xhci-hcd xhci-hcd.8.auto: Cannot set link state. [ 880.947492] usb usb5-port1: cannot disable (err = -32) [ 880.948328] scsi host0: uas_post_reset: alloc streams error -19 after reset [ 880.952607] sd 0:0:0:0: [sda] Synchronizing SCSI cache Edit: Looks like the latest jessie minimal also panics after disconnecting USB 3.0 device. Filed a issue on github, with ayufan (not sure if it was the right project page though). |
Rock64 No Audio @ Debian 12 | dmitrymyadzelets | 2 | 356 |
04-08-2024, 06:47 AM Last Post: dmitrymyadzelets |
OpenWRT on the Rock64 | CanadianBacon | 14 | 8,495 |
04-03-2024, 08:48 AM Last Post: helpmerock |
Rock64 bricked | shawwwn | 7 | 5,794 |
03-17-2024, 12:22 PM Last Post: dmitrymyadzelets |
Rock64 won't boot | luminosity7 | 10 | 4,300 |
03-16-2024, 08:33 AM Last Post: dmitrymyadzelets |
Rock64 doesn't boot | dstallmo | 1 | 366 |
03-16-2024, 08:29 AM Last Post: dmitrymyadzelets |
How well does Rock64 deal with HDR and Atmos on Kodi? | drvlikhell | 3 | 1,963 |
04-29-2023, 04:24 AM Last Post: newestssd |
Rock64 board not working, no HDMI no Ethernet. | EDited | 3 | 3,594 |
01-17-2023, 02:31 PM Last Post: Flagtrax |
ROCK64 v3 can it boot from USB? | Tsagualsa | 4 | 2,171 |
11-29-2022, 11:31 AM Last Post: Macgyver |
rock64 v3 spiflash | Macgyver | 0 | 778 |
11-28-2022, 02:18 PM Last Post: Macgyver |
my rock64 dosen't work | rookie_267 | 0 | 979 |
10-07-2022, 07:50 PM Last Post: rookie_267 |
