Archlinux (mainline) for Pinebook
#41
alankao, That's strange. Well, I've tried Arch on my 1080p Pinebook (not a manually downloaded image, though). You can choose Arch from installer's dropdown menu, and it booted and worked fine.
#42
The u-boot included with that image doesn't work for some of the pinebooks. You can try to flash a newer one.
Enviado desde mi ONEPLUS A5010 mediante Tapatalk
#43
(11-29-2018, 12:19 AM)UltraBloxX Wrote: alankao, That's strange. Well, I've tried Arch on my 1080p Pinebook (not a manually downloaded image, though). You can choose Arch from installer's dropdown menu, and it booted and worked fine.
Hi UltraBloxX,
Thanks for sharing your experience.  I did flash it from the installer.
Now I suspect that a 128G micro SD might be too large for the booting process,
so I will try a smaller one instead.
BTW, is it true that the first boot takes more than 10 minutes?
Thanks!
#44
Just in case, and while the u-boot is still old, you can use the following workaround (in my case, flashing the microsd):
  • Flash the image:
dd if=./archlinux-xfce-pinebook-20181104.img of=/dev/sdb bs=4M oflag=direct status=progress
  • Flash an updated u-boot:
dd if=./u-boot-sunxi-with-spl-pinebook.bin of=/dev/sdb bs=8k seek=1
I'm using @gamiee updated u-boot (I've attached here just in case)
NOTE: I've added the pdf extension to the u-boot file otherwise I couldn't attach it to the post.
HTH!
.pdf   u-boot-sunxi-with-spl-pinebook.bin.pdf (Size: 604.14 KB / Downloads: 316)
#45
Anarsoul's Arch has been upgraded to 4.20
#46
Heart
I'm currently very happy and wanted to thank Anarsoul & all of you for your work - I used the SD card image to boot up my Pinebook 1080p today and used it to pacstrap Arch Linux to the eMMC with my specific needs (encrypted LVM, LXQt).
By peeking at what Anarsoul's scripts do when creating an image & combining that with my AMD64 Arch installation experience, it was very simple.
Now I finally have a system exactly the way I like it (especially I can put sensitive stuff on it now because I don't have to fear to forget the Pinebook somewhere anymore).
So really, thank you very much.
I was a little bit worried about the speed drop due to the encryption, but it's barely noticeable.
#47
(01-20-2019, 12:05 PM)Blutkoete Wrote: I'm currently very happy and wanted to thank Anarsoul & all of you for your work - I used the SD card image to boot up my Pinebook 1080p today and used it to pacstrap Arch Linux to the eMMC with my specific needs (encrypted LVM, LXQt).
Would you mind to write up a guide or something? I think it would be really helpful for folks with little arch experience Smile
Thanks!
#48
Thanks!
Sorry for the delay: https://forum.pine64.org/showthread.php?tid=7173
#49
So great! Thanks!
#50
Anyone else have trouble updating their Arch distro? Twice now after an update its done something to the resolve.conf and then paceman can no longer resolve hostnames. This makes Pacman die most spectacularly. The last time I reverted to an unchanged resolve.conf and that worked. But this time I have been unable to get it to work. The annoying thing is drill seems to work just fine. Drill <hostname> seems to find the info without any issues, but paceman and the web are broken.
Much as I love Arch, this kind of strange behavior is enough to make me go look for another distro that works as expected.
And yes, I understand that Arch is not a distro for newbies, but i've been running it off and on for the past 6=8 years and this is the first time i've had this trouble.
  DietPi OS for Pinebook MichaIng 3 5,361 03-11-2024, 05:02 PM
Last Post: oxoocoffee
  Slarm64 on Pinebook [Slackware Arm - 64 bit] KRT 46 60,825 09-26-2023, 03:18 PM
  Broke pinebook GUI, what to do, fix or install new? acruhl 2 884 07-13-2023, 05:43 PM
Last Post: acruhl
  Orignal PineBook jwp1000 1 679 07-10-2023, 07:44 AM
  Pinebook no longer boots rjtanner 12 3,564 04-13-2023, 01:09 PM
Rainbow Customised (encrypted) eMMC installation using Anarsoul's ArchLinux Blutkoete 24 34,518 05-02-2022, 12:59 PM
Last Post: thunderweasel
  Stock Debian on original Pinebook moonwalkers 1 3,213 01-29-2022, 10:37 PM
Last Post: cel
  Write image to eMMC - Pinebook 11.6" irongarment 4 3,840 01-04-2022, 09:22 PM
Last Post: irongarment
  E: The repository 'http://pinebook.kde.org.uk bionic Release' no longer has a Release pixelpaperyarn 3 5,227 05-07-2021, 10:20 AM
  pinebook.kde.org.uk no longer has release file?? supermassive 1 3,802 01-20-2021, 11:18 AM
