Archlinux (mainline) for Pinebook
Second release of Anarsoul's Arch with mainline kernel for A64 devices can be found here
Here's Archlinux image for Pinebook (and Pine64, SOPINE - but beware - these are not tested, I tested only Pinebook image)
2017-07-08: Initial release
Credentials: alarm/alarm, root/root
https://github.com/anarsoul/linux-build/...g/20170708
You can use nmtui to connect to your WiFi network.
Thank you anarsoul ;  nice work !
Big Grin
Hi Anarsoul, thanks for adding Arch back to the build system!
Thanks for this image. I'm feeling like a newb here. I installed this image to my sd card and booted my pine book. I then followed these steps to install lxdm, xorg, mate-desktop on it and now when I reboot I get 4 pine cones in the upper left corner of the screen. what did I do wrong here?
instructions.
https://www.ostechnix.com/install-mate-d...rch-linux/
(07-10-2017, 11:31 AM)eclay Wrote: Thanks for this image.  I'm feeling like a newb here.  I installed this image to my sd card and booted my pine book.  I then followed these steps to install lxdm, xorg, mate-desktop on it and now when I reboot I get 4 pine cones in the upper left corner of the screen.  what did I do wrong here?
instructions.
I guess I should clarify my request.  Is there anything special or specific to getting xwindows running on arch linux on the pinebook?
(07-11-2017, 09:36 AM)eclay Wrote:
(07-10-2017, 11:31 AM)eclay Wrote: <snip>
If you want to run Xorg, and the mate desktop, don't use the archlinux image;  rather, use the ubuntu mate image.  Neither here not there, it would seem that you borked the boot-up somehow.  Obviously, you will need to start over;  but, you might want to consider why you're running arch in the first place?
What do you want to accomplish with your pinebook;  ubuntu mate will probably work fine for you.
On the other hand;  did you get a logon prompt with the four pinecones ??
If so, then logon and start the desktop by trying:
  startx
cheers
Hello.
Can I know if Archilinux is a good distribution for our Pinebook ? I have never tested this distribution, I wonder if it's a good solution. Because I'm so satisfy about Ubuntu Mate. I can work with it, I can see videos with VLC...
(07-15-2017, 09:28 AM)jmbernabotto Wrote: Hello.
Most folks are using the ubuntu mate image;  I would recommend you stay with that;  it is customized for the Pinebook, and has been tricked out for all hardware , including the mic(s) now.
archlinux is a good headless solution, and a good experimental gnu+linux distro for playing with and learning linux;  ubuntu mate is more of a complete package; and better user experience.
Thanks marcushh777.
I can say that I know linux, just a little bit, but I'm able to make some basics works !
I've tested a lot of distro, I like it ! SO, I think that I'm going to test Archilinux !!
What would be cool, would be a minimal package to bootstrap the armv8 Arch Linux ARM tar, as I'm not a fan of images ^^
  DietPi OS for Pinebook MichaIng 3 5,357 03-11-2024, 05:02 PM
Last Post: oxoocoffee
  Slarm64 on Pinebook [Slackware Arm - 64 bit] KRT 46 60,780 09-26-2023, 03:18 PM
  Broke pinebook GUI, what to do, fix or install new? acruhl 2 884 07-13-2023, 05:43 PM
Last Post: acruhl
  Orignal PineBook jwp1000 1 679 07-10-2023, 07:44 AM
  Pinebook no longer boots rjtanner 12 3,564 04-13-2023, 01:09 PM
Rainbow Customised (encrypted) eMMC installation using Anarsoul's ArchLinux Blutkoete 24 34,503 05-02-2022, 12:59 PM
Last Post: thunderweasel
  Stock Debian on original Pinebook moonwalkers 1 3,213 01-29-2022, 10:37 PM
Last Post: cel
  Write image to eMMC - Pinebook 11.6" irongarment 4 3,834 01-04-2022, 09:22 PM
Last Post: irongarment
  E: The repository 'http://pinebook.kde.org.uk bionic Release' no longer has a Release pixelpaperyarn 3 5,224 05-07-2021, 10:20 AM
  pinebook.kde.org.uk no longer has release file?? supermassive 1 3,802 01-20-2021, 11:18 AM
