Pine Phone won't boot into recovery mode
I have a pinephone pro explorer edition which just simply refuses to boot into recovery mode. I am trying to put arch-arm onto it, I've flashed the microSD, put it in the phone, but I cannot get the phone to boot from it or boot into recovery mode. I have tried every method I could find. Every time it either boots into the current os, or the led flashes red a bunch of times and the phone vibrates a lot before just turning off again. I have tried multiple SD cards and multiple flashes. No clue where to go from here it's been driving me nuts all week.
(02-17-2023, 06:50 PM)ninjapig26@gmail.com Wrote: I have a pinephone pro explorer edition which just simply refuses to boot into recovery mode. I am trying to put arch-arm onto it, I've flashed the microSD, put it in the phone, but I cannot get the phone to boot from it or boot into recovery mode. I have tried every method I could find. Every time it either boots into the current os, or the led flashes red a bunch of times and the phone vibrates a lot before just turning off again. I have tried multiple SD cards and multiple flashes. No clue where to go from here it's been driving me nuts all week.
technically speaking, there is no "recovery". you probably meant tow-boot's usb mass storage mode. if there is a screw up in tow-boot, you probably need to reinstall it, https://tow-boot.org/devices/pine64-pinephonePro.html .
you may have to use "re" button to boot sdcard, https://wiki.pine64.org/wiki/PinePhone_Pro#Boot_order .
Well I've certainly tried holding "re" to boot from sd to no avail, as well as every other possible button combination I could think of. I'm not familiar with what tow boot is or how to use it. I'll have a read and see what I can do, thanks for your time.
Please double-check, does the button label state "RESET" or "RE"? What is the exact filename of the image you were flashing on the microSD card and what is the exact tool or full command you used for flashing? Make also sure the microSD card is in the top slot.
  Pine Phone Pro audio on phone calls: discussion, support and tips apink 43 13,497 Yesterday, 09:14 AM
Last Post: lightwo
  Tow-Boot, a new U-Boot option for Pinephone Pro and other devices Ulfnic 60 46,156 02-13-2024, 02:54 PM
Last Post: fxc
Brick Recovery without Tow Boot b34ux 10 1,588 02-02-2024, 07:07 PM
Last Post: reky
  Guide to Suitable Phone State Borealid 19 11,078 09-18-2023, 07:00 AM
Last Post: robocone
  What to do if your PinePhone Pro does not boot fxc 19 19,929 09-10-2023, 03:19 AM
Last Post: fxc
  Phone Attitude(Device orientation) lurkadillian 2 1,100 06-22-2023, 08:12 PM
Last Post: lurkadillian
  PP Pro caught in Mask Rom Mode? nieral 2 1,254 03-06-2023, 04:10 PM
Last Post: fxc
  tow-boot installation problem techariah 2 1,561 02-16-2023, 02:50 PM
Last Post: techariah
  [Mobian] No return from locked phone arno_nuehm 1 1,070 02-06-2023, 07:57 AM
Last Post: arno_nuehm
Wink Monitor mode packet injection and external wireless adapter chedder_bob 2 2,238 01-05-2023, 01:38 AM
Last Post: RTP
