sudo nano file saving pinephone beta edition
I have run into a simple yet gamebreaking issue. My virtual keyboard does not recognise the ctrl+x input that would allow me to save changes in files. or rather.
I've run into the issue of the screen shutting off after a half second when not on charge (and only when not charging), but have been trying to manually change the screen settings in powermanagementprofilesrc file. but because I cannot save my changes, my phone is unusable when not on charge. what could I possibly be doing wrong?
I am running kde plasma, for reference. and let it be known I am a recent convert from windows and ios, and have minimal knowledge of linux.
(12-15-2022, 10:41 PM)CharlesGnarley Wrote: I have run into a simple yet gamebreaking issue. My virtual keyboard does not recognise the ctrl+x input that would allow me to save changes in files. or rather.
See this: https://forum.pine64.org/showthread.php?tid=15216
That did the trick, thanks heaps.
For posterity if that thread gets taken down, the solution is to press control then press escape twice and THEN hit x
No idea why using the konami code makes it work, but it is what it is
Quote:For posterity if that thread gets taken down, the solution is to press control then press escape twice and THEN hit x
No idea why using the konami code makes it work, but it is what it isgeometry dash subzero
I tried that but it didn't work?
For the record, the most convenient way under Plasma Mobile to set power management settings that the mobile settings page does not support (e.g., to never suspend the phone when it is plugged in) is to force bringing up the desktop version of the settings with kcmshell5 powerdevilprofilesconfig.
  PinePhone - boot from microSD laserpyramid 9 793 05-03-2024, 10:09 AM
Last Post: laserpyramid
  pinephone virtual keyboard aular 4 412 04-10-2024, 03:45 PM
Last Post: aular
  PinePhone Doesn't Boot LED Doesn't Show Any Signs When Charging dorkydev 1 274 04-02-2024, 11:50 AM
  Are you using the Pinephone as your daily driver? jro 157 110,605 02-18-2024, 11:33 PM
Last Post: aular
  2020 PinePhone Manjaro CE EU for sale, name your price astrojuanlu 7 1,908 02-14-2024, 04:51 PM
Last Post: astrojuanlu
  pinephone is not bootble for the box. ijij 1 654 01-19-2024, 01:29 PM
Last Post: fxc
  Multiple issues with the Pinephone MTXP 12 2,488 12-28-2023, 07:55 AM
Last Post: MTXP
  pinephone repair shop shengchieh 0 534 12-26-2023, 02:42 PM
Last Post: shengchieh
  Can't get Mobian on PinePhone to recognise USB-C docking bar duncan_bayne 9 7,064 12-04-2023, 02:14 AM
Last Post: Peter Gamma
  Pinephone not booting, always vibrating alexander12 7 5,084 11-22-2023, 06:46 PM
Last Post: Scary Guy
