sudo nano file saving pinephone beta edition
I have run into a simple yet gamebreaking issue. My virtual keyboard does not recognise the ctrl+x input that would allow me to save changes in files. or rather.
I've run into the issue of the screen shutting off after a half second when not on charge (and only when not charging), but have been trying to manually change the screen settings in powermanagementprofilesrc file. but because I cannot save my changes, my phone is unusable when not on charge. what could I possibly be doing wrong?
I am running kde plasma, for reference. and let it be known I am a recent convert from windows and ios, and have minimal knowledge of linux.
(12-15-2022, 10:41 PM)CharlesGnarley Wrote: I have run into a simple yet gamebreaking issue. My virtual keyboard does not recognise the ctrl+x input that would allow me to save changes in files. or rather.
See this: https://forum.pine64.org/showthread.php?tid=15216
That did the trick, thanks heaps.
For posterity if that thread gets taken down, the solution is to press control then press escape twice and THEN hit x
No idea why using the konami code makes it work, but it is what it is
Quote:For posterity if that thread gets taken down, the solution is to press control then press escape twice and THEN hit x
No idea why using the konami code makes it work, but it is what it isgeometry dash subzero
I tried that but it didn't work?
For the record, the most convenient way under Plasma Mobile to set power management settings that the mobile settings page does not support (e.g., to never suspend the phone when it is plugged in) is to force bringing up the desktop version of the settings with kcmshell5 powerdevilprofilesconfig.
  Pinephone visibly losing power while plugged in Hiraghm 11 10,787 Yesterday, 12:23 AM
Last Post: NorrisFByrd
  Pinephone software Csanderson0313 3 2,289 07-10-2026, 02:21 PM
  PinePhone Game Thread PixelPaintbrush 31 90,136 06-11-2026, 02:50 PM
Last Post: elinkser
  How can I record video on a Pinephone? kk22 23 27,719 03-25-2026, 12:55 PM
Last Post: baptx
  pinephone-support package not upgradable on Mobian fhireman 5 9,443 02-28-2026, 05:49 PM
Last Post: baptx
  beep - playing PCM samples on PinePhone? WhiteHexagon 0 1,938 12-04-2025, 08:07 AM
Last Post: WhiteHexagon
Star Selling my Pinephone Pro Explorer Edition zheyon 2 5,691 12-01-2025, 10:25 AM
  PinePhone sensors - Gyroscope power WhiteHexagon 3 3,289 11-30-2025, 08:07 AM
  Light Sensor / Proximity Sensor on PinePhone? WhiteHexagon 1 2,718 11-18-2025, 03:07 PM
  Pinephone boot. Richy_T 8 9,238 10-21-2025, 12:12 PM
Last Post: Richy_T
