Install Tow-Boot on the SPI
I wanted to post the steps to installing Tow-Boot on the SPI.
Sorry if this is long and drawn out but I am writing this to help anyone new to Linux. With Manjaro being preinstalled from the factory it was best to write this using Manjaro specifics. I tried following the guides on the Tow-Boot website, Pine Wiki and the Manjaro Wiki but was unsuccessful. I would suggest reading these to conceptually understand what you are doing if you are new. You will need mtd-utils installed first for this to work. Now I would download the release you need and extract the file into a folder. I was not successful in getting the spi.installer.img to boot after flashing to a SD card to install using the directions provided in the reference section.
I used the method below under coding and it only took me about 3 minutes to accomplish this task.
I did all this on Manjaro but to my understanding other distributions should work the same.
References:
https://tow-boot.org/devices/pine64-pinebookPro.html
https://wiki.pine64.org/wiki/Pinebook_Pr...ash_device
https://wiki.manjaro.org/index.php/Manja...ptional.29
Required Dependencies:
mtd-utils - https://software.manjaro.org/package/mtd-utils
Download Tow-Boot file:
https://github.com/Tow-Boot/Tow-Boot/releases
(I installed pine64-pinebookPro-2021.10-005.tar.xz - https://github.com/Tow-Boot/Tow-Boot/rel...005.tar.xz)
Step 1. I opened the terminal and "cd"d my way into the correct location to find the file "Tow-Boot.spi.bin" or depending on the distribution you are using you can also find the file, right click and got to "Open Terminal Here" - For this install it was located under the binaries folder.
Step 2.
sudo flashcp Tow-Boot.spi.bin /dev/mtd0
The entire flash took about 15 seconds for my Pinebook Pro.
Step 3: Restart (be ready to hit the "Esc" button)
I hope this helps others.
And..... the reason for that is that a uboot for SD/emmc is DIFFERENT than one for SPI
(this applies to ANY uboot, not just tow-boot)
the code is the same,,, but idbloader is expanded with blank sectors and ALSO
starts at offset 0, not 64 sectors.. IIRR uboot itself is also at 6M, not 8M
If you use the right image, tow-boot on SD/emmc will work OK
(10-31-2022, 10:51 PM)wdt Wrote: > I was not successful in getting the spi.installer.img to boot after flashing to a SD card
I'm afraid even if you use the right image  Tow-Boot will not work for many Pinebook Pro  people with certain models.  I and  others spent many days trying to diagnose why  mine and some other people could not get Tow-boot to load  or display whether we  had it on SD card or different version as required for loading directly into the SPI.
It appears Tow-boot is there but it's invisible, screen is dark blue, you can not see the menu.   The Above method did not work for me or others.  I used  Manjaro, PostmarketOS  and ArmBian.  Until this Display Bug is fixed  in Tow-Boot   (and PostmarketOS  U-BOOT also), we can not use  these type of loaders.
TL_Lim  reported in  the Pine64 Pinebook live chat he thinks it is caused by   a bug in  Tow-Boot  Display driver
"<tl_lim> @River-mochi, from the chat log, I suspect is tow-boot's display driver bug. From your description, your PBP indeed boot up from the tow-boot SD card and your observe the green status LED. My takes the LCD display driver that tow-boot using may not have correct LCD timing and cause some LCD display cannot lock the display team and this is why no display. I think someone already file such issue on tow-boot GitHub and hopefully this issue can be resolved soon by update LCD driver. I think your PBP SPI Flash is OK and no need to desolder."
People with newer Pinebook Pro's from 2022 seem to be ok, my Pinebook Pro was made around March 2020.
If your supposition is right, then an earlier tow-boot version should display,
have you tried the earliest version you can find?
I base this guess on the date of the pbp,,,, mar 2020, hard to imagine
that the bug could hide so long,,, so a regression
Alas, this is not uncommon
My model, which I received a couple weeks ago, will not boot to ANYTHING except eMMc. By that I mean, there is no blank or invisible display, no seemingly boot but doesn't work, no error messages, no beeps or warnings...just ignores the SD card and continues right into Manjaro. Unfortunately, I attempted to open up my box and look for the eMMc disable switch but didn't see any way to push it, toggle it, slide it, or otherwise do anything to a little brown box that looks like a switch and matches the location of the picture. So I guess I am stuck with a boat anchor that I can't configure and work with. Any hope for me or should I look elsewhere? I've done the Google search, the forum tour, the NOOB site, the Manjaro site, the PINE64 site. Bummer!
(11-30-2022, 02:06 PM)GreyHobbyist Wrote: My model, which I received a couple weeks ago, will not boot to ANYTHING except eMMc. By that I mean, there is no blank or invisible display, no seemingly boot but doesn't work, no error messages, no beeps or warnings...just ignores the SD card and continues right into Manjaro. Unfortunately, I attempted to open up my box and look for the eMMc disable switch but didn't see any way to push it, toggle it, slide it, or otherwise do anything to a little brown box that looks like a switch and matches the location of the picture. So I guess I am stuck with a boat anchor that I can't configure and work with. Any hope for me or should I look elsewhere? I've done the Google search, the forum tour, the NOOB site, the Manjaro site, the PINE64 site. Bummer!
The picture does *not* match your PBP.  The switch does exist but it does not look like the one in the picture and is not in the same location.  You'll have to find it as unfortunately I don't recall where it is.  But I think it is still near the eMMC.
But even without opening the PBP, you should be able to flash Tow-boot to the SPI-ROM, from Manjaru, if that's what you intend to do.  It would solve your problem, assuming you don't have the aforementioned problem with Tow-boot not working.
Just to be clear, your problem is due to the U-boot that comes pre-installed on the eMMC of the latest batch of PBPs (and possibly earlier ones).  It also might get installed to older ones during the Manjaru update process.
:wq
[ SRA accepts you ]
give a photo of the Bottom of your  PCB  the part near the  EMMC  is what you want EMMC is next to large RF metal shiny shield.
Where did Tow-Boot go to? It's no longer at tow-boot.org or at github.com.
what is this ?
ezik
I have a PBP without an emmc. I used to boot Manjaro ARM from the SD card fine, but now that isn't working. I'd also like to install, and boot from, an NVMe.
Would Towboot help my situation?
I plan to follow the directions here: https://tow-boot.org/devices/pine64-pinebookPro.html
Question Can't Boot from MicroSD (What Am I Missing) falken 10 4,065 04-28-2023, 04:26 PM
Last Post: pinemouth
  How to install Ubuntu to eMMC and to install KDE (Neon) Wizzard 66 100,089 12-22-2020, 03:05 PM
Last Post: Wizzard
  Video : How to install Armbian Reforged and set it up on PineBookPro / Gaming image NicoD-SBC 0 2,794 11-23-2020, 12:09 PM
Last Post: NicoD-SBC
  Extracting a copy of SPI NOR flash contents using micro SD card and u-boot hmuller 0 2,747 09-21-2020, 11:24 AM
Last Post: hmuller
  Program SPI NOR Flash on Pinebook Pro with u-boot on micro SD Card hmuller 0 3,467 09-21-2020, 10:02 AM
Last Post: hmuller
  Citrix Receiver / ICAClient install for armhf Arwen 7 15,376 09-14-2020, 11:02 PM
Last Post: vb_linux
  How to boot Manjaro from NVME with uboot on eMMC as400 47 57,418 06-07-2020, 02:37 AM
Last Post: as400
  How to get kernel boot messages on screen on Manjaro as400 2 4,380 01-23-2020, 04:35 PM
Last Post: as400
  Dual booting Linux with ChromiumOS using "boot floppy" Wizzard 5 7,098 11-28-2019, 12:23 PM
Last Post: TDC_PBP
