Comparing the Librem 5 USA and PinePhone Beta
I wrote up some observations about the differences between the L5USA and PP:
[Image: l5-vs-pp-side-view.jpg?fit=440%2C330]
I would like to hear any feedback/critiques and know whether other people are seeing the same performance differences between the two phones.
I’ll probably post more observations later about the PP on my blog, now that I have it in my grubby little hands and can try using it as a phone. Sadly, I had to send the L5USA back to Purism for servicing and I don’t know when I’ll get back to the US to pick it up.
It's super long, so it might probably take me many weeks to get through it I think.
But I went through a little bit, and one thing caught my eyes:
[Image: l5vspp_thermals.jpg?w=1024]
I noticed an "X" button on the Librem screen, but not on the Pine screen.
Was this button present on the Librem 5 from the very beginning, or did you enable it by yourself?
In the case of the latter, which Gsetting is that?
母語は日本語ですが、英語も喋れます(ry
@amosbatto  thank you for the detailed comparison. It is super interesting. That must have been a lot of work!
The more I read about the Librem5, the more I like it. I don't mind the price; however I cannot justify to myself spending more than the combined cost of my last four cars, let alone to my wife!
Thank you for he write up.
:wq
[ SRA accepts you ]
(12-10-2021, 07:06 PM)ryo Wrote: I noticed an "X" button on the Librem screen, but not on the Pine screen.
In "dconf editor", go to "org / gnome / desktop / wm / preferences / button-layout" -> use default value ("appmenue:close")
On my PineTab it will be set back when docked -> undocked
(12-10-2021, 07:06 PM)ryo Wrote: In the case of the latter, which Gsetting is that?
This should do it:
gsettings set org.gnome.desktop.wm.preferences button-layout ":close"
Going back to normal is a
gsettings set org.gnome.desktop.wm.preferences button-layout ""
away.
This should do it:
away.
Thanks, this worked.
I toyed around with it by adding the other 2 buttons, but seems like those did nothing, so I removed maximize and minimize again, but I'll keep the close button.
  PinePhone - boot from microSD laserpyramid 7 637 04-25-2024, 05:56 AM
Last Post: aular
  pinephone virtual keyboard aular 4 369 04-10-2024, 03:45 PM
Last Post: aular
  PinePhone Doesn't Boot LED Doesn't Show Any Signs When Charging dorkydev 1 249 04-02-2024, 11:50 AM
  Are you using the Pinephone as your daily driver? jro 157 109,735 02-18-2024, 11:33 PM
Last Post: aular
  2020 PinePhone Manjaro CE EU for sale, name your price astrojuanlu 7 1,858 02-14-2024, 04:51 PM
Last Post: astrojuanlu
  pinephone is not bootble for the box. ijij 1 626 01-19-2024, 01:29 PM
Last Post: fxc
  Multiple issues with the Pinephone MTXP 12 2,412 12-28-2023, 07:55 AM
Last Post: MTXP
  pinephone repair shop shengchieh 0 512 12-26-2023, 02:42 PM
Last Post: shengchieh
  sudo nano file saving pinephone beta edition CharlesGnarley 4 1,742 12-22-2023, 03:44 PM
  Can't get Mobian on PinePhone to recognise USB-C docking bar duncan_bayne 9 7,009 12-04-2023, 02:14 AM
Last Post: Peter Gamma
